Solid Top mounts slipping
  • Ski
    • 2591
    Hi Chaps.
    after driving around with a loud clunking sound at the front (getting louder and louder) I noticed the centre adjustable "NUT" within the QRS solid top mount un-done itself or slipped a couple of threads not sure. Either way when jacked up I could lift the wheel and notice the top mount move half an inch under the bonnet. Tightened it back up and job solved, no more clunking.
    However, its happening again. (1 day later)
    Any BTDT? do I need to replace it or just use more power when tightening it?
    top mount has (from outside in):
    an outside oval adjustable peice
    inside bolt/nut
    very center allen key bolt
    Its the inside bolt/nut which keeps slipping. (I cannot tell if its unscrwing itself, or jumping screw threads.
    Any idea's ?
    ABY Coupe
  • Dpicariello
    • Mar 2006
    • 621
    Isn't the nut a nyloc one?
    If so and the nylon insert is still good then it certainly shouldn't be undoing itself. I reckon change the nuts and check the threads too.
    Dan
    • mcandmar
      • Apr 2004
      • 5118
      The versions i have seen didnt have a nylon nut, or any locking mechanism. Also check the ball isnt worn out on them, mine were done for after a few years.
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
      • Fat Audi 80
        • 10547
        What about getting a lock nut to go on top? (If you have enough threads left)
        They are standard Metric threads are they not?
        Cheers,
        Steve.
        The Perfectionist
        • Baldy
          • 469
          • Home: Sikkim Current: British Antarctic Territory
          just run some locthread/nutloc round the thread before tightening up.
          should be no rattling loose afterwards
          Nautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management The old Bus
          0-60 4.9
          1/4mile 13.5
            Personally ditch them and get 034 mounts
            • anton
              • Jan 2005
              • 802
              I had this problem initially but then i got an air ratched on it and its hasnt come loose since....i actually highly recomend these, have lasted well too, a year on and not any wear at all....and thats with kw coilovers.....
              Ant
              91' Coupe quattro 20v - project
              KW V2s and other goodies
              now gone
              03' BMW 330CI - Sold
              08' A5 Coupe 3.0l tdi quattro - Sold
              57' BMW 525d M Sport Touring
