KW suspension help
  • Pirvu Eugen
    • Apr 2007
    • 1978
    • Country: Romania
    KW suspension help
    Hello!
    Please help me with this!
    I have bought an Variant 2 KW suspension for my project but i forgot to take also the caps from the top off the springs... like in the picture.
    Can you, please, give me the dimensions from those caps? how they are fitted?
    They are realy from plastic?
    Sorry for soo many questions!
    Thank You very much!
    All the best!
    Eugen
  • Lupo911
    • Apr 2005
    • 312
    Originally posted by Pirvu Eugen
    Hello!
    All the best!
    Eugen
    These "Caps" upper Springseat are a Composite Material (ABS/GFK), if you are ordered this KIT directly from KW, you should have these Caps already pre Assembled in your Box. If you dont have these Caps, please order these from KW, to avoid some Problems or Malfunctions with selfmade Seats. Make sure you will get the rigth ones with 20mm inside Diameter (V1 and V3 using 22mm).
    • Pirvu Eugen
      • Apr 2007
      • 1978
      • Country: Romania
      I will try to order them at KW.
      All the best!
      • kwlw
        • Sep 2004
        • 1025
        • Country: Lithuania
        All the best!
        What suspension you are running at the moment? Typ85, Typ89, mixed?
        Sau
        • Pirvu Eugen
          • Apr 2007
          • 1978
          • Country: Romania
          Is complete from an S2 3B Coupe.
          • sailaz
            • Oct 2009
            • 647
            • Country: United Nations
            Hi guys,
            Maybe someone has dismantled KW coilovers in the past and made photos and wouldn't mind to share them ?
            Actually I'm interested what I will find when I unscrew this cap
            • terrybullwon
              • Mar 2006
              • 8782
              Nothing for the first 250mm and then there will be the shim stack and piston.
              There will be oil and gas
              Chef
              • sailaz
                • Oct 2009
                • 647
                thanks for such precise explanation, I like it.
                Will oil come out when I unscrew this cap ? I'm wondering if I can replace by myself cartridge inside this strut ?
                • terrybullwon
                  • Mar 2006
                  • 8782
                  Is there a seal on the piston shaft in the picture?
                  Chef
                  • sailaz
                    • Oct 2009
                    • 647
                    Can't check right now, but you mean seal over here ??
                    P.S> explanation from KW regarding this issue: -- Unfortunately are the cartridge dampers no more available anymore. We have exchanged those into wet build. You need to order 2 complete new struts w/o spring. --
                    cartridge damper - what it is ?
                    • andy10v
                      • 5996
                      Older KWs used Koni inserts
                      Sold ABY-stock
                      • sailaz
                        • Oct 2009
                        • 647
                        Yes, earlier they were using Koni's, latest was AL-KO, but question remains: why KW is not servicing this strut and what is 'cartridge damper' and what means 'wet build' ?
                        • andy10v
                          • 5996
                          To me that would mean
                          Cartridge-a sealend insert, like a shock you fit in a housing/strut
                          Wet-a shock that uses the strut body to contain the oil
                          Sold ABY-stock
                          • sailaz
                            • Oct 2009
                            • 647
                            cap unscrewed, no oil, AL-KO Sport cartridge inside ...
