adjusteble rear tie rod for avant.
  • lind4hl
    • Jul 2008
    • 2465
    im just wondering if someone is interested of these in ss 316l (stainless) with uniballs in each end. and adjusteble on the middle. i will try some paint skills so you see what im talking about.
  • stiglet
    • Aug 2007
    • 1264
    Similiar to 034? Yes please.
    • redz
      • 222
      I'd be interested
      s2 new project
      On going !!!
      • stiglet
        • Aug 2007
        • 1264
        Is the thread going to be SS?
        • lind4hl
          • Jul 2008
          • 2465
          a quick image to all intrested it will be a 16mm tube (or something like this) in stainless 316l weldon nuts and uniballs in ss316l and nuts/bolts etc. has not start to work on it before yesterday. I have only 2 problems, first i must understand why it is bent, because bumpsteer maybe? i will make a straight pipe of this is working, otherwise i will bend it and the bolt at the subframe, this hole is not round so must make somthing for that. but a picture so you know what im talking about.
          • stiglet
            • Aug 2007
            • 1264
            It will be bent to avoid something, like the subframe. Makes no difference to bump steer.
            You can buy reverse threaded heim joints if thats helps, then it will act like a proper adjuster. If you can get away with making it straight that is.
            • lind4hl
              • Jul 2008
              • 2465
              i was thinking of this if i can make it straight there will be reversed threads,
              what do you all thinking of material? im going to check during the weekend if i need m10 or m12 uniball and the pipe diameter? 16x2mm or something maybe?
              edit: i will make a kit to my car and se what materials cost and then i can take "orders" ?
              • lind4hl
                • Jul 2008
                • 2465
                something like this then?:
                • lind4hl
                  • Jul 2008
                  • 2465
                  i will go to the garage today and start looking on these things, i also have an idea, why not use the oem bolt at the subframe so you can first adjust there, and if you want more agressive toe in (for trackdays etc.) you will adjust on the tie rod? that would be easiest to do, since the bolt hole in the subframe isnt perfectly a circle. so if you use an regular bolt maybe it will adjust itself when it getting to much pressure, and that we dont want
                  • stiglet
                    • Aug 2007
                    • 1264
                    Any chance you could make the outer thread the standard fitment, so that you have the option of using a standard tie-rod end instead of a heim joint? That would make the whole thing a bit less costly and not much less as stiff
                    • lind4hl
                      • Jul 2008
                      • 2465
                      i build to myself for stifness, but i can look at that also
                      • stiglet
                        • Aug 2007
                        • 1264
                        That would be cool Otherwise it gets complicated when you have to source a tapered rod to fit in the steering arm.
                        • lind4hl
                          • Jul 2008
                          • 2465
                          i will have a look today, take som pics and measurements, will write tonight/tomorrow
                          • goodall
                            • Jul 2008
                            • 810
                            is stainless really best option is not abit brittle?
                            • stiglet
                              • Aug 2007
                              • 1264
                              I was thinking the same, but I think as long as the thread isn't made of SS it might be ok?
