im just wondering if someone is interested of these in ss 316l (stainless) with uniballs in each end. and adjusteble on the middle. i will try some paint skills so you see what im talking about.
adjusteble rear tie rod for avant.
a quick image to all intrested
it will be a 16mm tube (or something like this) in stainless 316l weldon nuts and uniballs in ss316l and nuts/bolts etc. has not start to work on it before yesterday. I have only 2 problems, first i must understand why it is bent, because bumpsteer maybe? i will make a straight pipe of this is working, otherwise i will bend it and the bolt at the subframe, this hole is not round so must make somthing for that. but a picture so you know what im talking about.
One thing i've learned we are way behind the Scandinavians!Comment
It will be bent to avoid something, like the subframe. Makes no difference to bump steer.
You can buy reverse threaded heim joints if thats helps, then it will act like a proper adjuster. If you can get away with making it straight that is.Comment
i was thinking of this if i can make it straight there will be reversed threads,
what do you all thinking of material? im going to check during the weekend if i need m10 or m12 uniball and the pipe diameter? 16x2mm or something maybe?
edit: i will make a kit to my car and se what materials cost and then i can take "orders" ?Last edited by lind4hl; 4 December 2008, 17:53.
i will go to the garage today and start looking on these things, i also have an idea, why not use the oem bolt at the subframe so you can first adjust there, and if you want more agressive toe in (for trackdays etc.) you will adjust on the tie rod? that would be easiest to do, since the bolt hole in the subframe isnt perfectly a circle. so if you use an regular bolt maybe it will adjust itself when it getting to much pressure, and that we dont want
