Rattly rattle
    How are your engine mounts? Is the engine sitting low?
    Could be subframe mounts..
    • bertman
      • Apr 2007
      • 1173
      • Current: United Kingdom
      The engine is sitting a bit low john,not really sure how to check the subframe mounts other than to get a lever bar in there and see if there is any play in them,which there isn't,cause I have tried that already
      Got a few ideas to try and eliminate the problem,seeing as it quite apparent which side the noise is coming from.Going to change out the shock,if no joy then change the engine and g'box mount with some spare ones I have lying around
      If no joy,gonna get the marshmallows out and toast them over a nice warm avant
      Rob
      Ragussa green avant RS2+ spec
      Racing blue Octavia VRS mk2 estate-Remapped now to 250 bhp
      Audi coupe gt-slow as hell but loads of character-sold
      • Jas11n
        • 5067
        If you've got the 20p size mark on the sump, I'd say your engine mounts are maybe a bit worn. Hit a bump, the sump hits the subframe and there's your knock.
        Jase..
        2001 Avus Silver B5 RS4.
        1995 S2 Coupe - sold (sniff)
        • bertman
          • Apr 2007
          • 1173
          What is the best way to establish wether the engine mounts are boogered or not?
          That mark on the sump is still there Jase,but managed to wedge a bit of thick rubber between the subframe and the sump to try and rule the noise out.....noise is still there
          Rob
