Check your track rods!
    Failed MOT the other day on a couple of issues (rear discs, no brake assistance ) But the worrying thing was that one of the track rod end lock nuts was loose, chatting with a man who knows his stuff this is actually not all that unusual on the 2 due to the design of the track rod, the taper wears and the nut goes loose. (Nothing to do with my driving then ) You could actually wobble the rod adjuster up and down 3 mins with a spanner sorted it out but I'm tempted to get the alignment checked again.
  • stiglet
    • Aug 2007
    • 1264
    I've never heard of that before
    Is this the nut on the rod that goes through the steering arm or the nut on the adjuster side?
    • Acidburn
      • 13459
      Think he means the nut that is on the shock end, I had this come off on mine and I was seriously lucky I felt the vibration and slowed down, hence i've now double nutted that so it can't come off.
      • Mikes2
        • 1704
        this is why they are lock nuts and should be used once only and torqued correctly
        Mike
        http://www.s2-audi.co.uk
        • Rusty
          • 18953
          Yup. Replace them! I also use a clamp to press the ball joint into the socket fully when tightening otherwise tehy can spin out too easily.
