effects of RS2 FARB and std RARB on S2 Avant?
  • avants2turbo
    • Feb 2008
    • 1287
    as title says really,
    what sort of handling charateristics are going to appear with the fitting of a RS2 28mm FARB and leaving the RARB the standard S2 item?
    and can somebody confirm the RS2 FARB is 28mm and the standard one 26mm?
  • Rusty
    • 18953
    Theory says it'll understeer more in terms of balance but will be flatter.
    Better IMO to get S2Avant tested the Neuspeed RARB and leave the front stock.
    RS2 is either 27 or 28mm.
    Better to stop roll using increased spring rates really. I know a couple of the coupe lads are looking at no ARBs at all with coilies.
    • avants2turbo
      • Feb 2008
      • 1287
      hmm, that sounds about right
      Ive just bought a Whiteline rear ARB, and have been looking for a RS2 Front ARB for some time, as i wanted to fit them together, had the car up on the ramp at the weekend to replace 2 engine and 2 gearbox mounts, measured the front ARB and its 28mm which im sure was the size of the RS2 one...
      this would explain the terrible understear I get!
      am going to try and get the rear one on asap to see what difference it makes
      • Rusty
        • 18953
        It'll make it turn better. I'm running an OE 26mm up front and a 25mm at the rear. Not too mental
        How did you measure it? Best thing is a set of calipers, can be quite difficult otherwise.
        Try a 26mm front item if it is an RS2 one, did this to a mate's S4 with HnR ARBs, it was a bit dull on turn in so fitted a stock FARB and it was better.
          No need, if you put the whiteline on it will neutralise the handling.
          • Rusty
            • 18953
            Who wants neutral handling, oversteer is fun :mischeif: ... except when it happens unexpectedly on a slippery, narrow, twisty road in a car you've not owned very long
              lmao, always do them both together or rear only. don't do the front by itself that would be horrible to drive.
              • Rusty
                • 18953
                Amen brother, the ARB gospel according to the rev. J Amo
                  Can I get a witness?
                    First time you've ever wanted a witness Jamo?
                    • stiglet
                      • Aug 2007
                      • 1264
                      Tis funny, on the Golfs fitting a fat roll bar on the front can actually decrease understeer due to less body roll
                      • redz
                        • 222
                        I removed the front anitroll bar on my mk1 valver and had a massive shine racer anitroll bar at the rear.. made a very quick car through the twisty bits and track..
                        Andy
                        s2 new project
                        On going !!!
                        • Andreas
                          • Nov 2005
                          • 731
                          Testify! <:
                          I have the front stock and a whiteline RARB.. totally sweet <:
                          Andreas Lundstroem
                          A4 STCC Avant -04
                          Audi /S/2/ Sedan -94
                          prev.
                          Audi /S/2/ Coupe -91
                          • avants2turbo
                            • Feb 2008
                            • 1287
                            that really does explain alot!!
                            it was measured with a set of vernier calipers, supplied by our frendly Brembo man.. to measure disc thickness id guess
                            • Rusty
                              • 18953
                              Sounds like you gone got yourself an RS2 FARB then. If it's still a bit inert then try an OE 26mm item and see what you think. If you're running lowering springs then it'll roll less anyway.
