UrS4 ARB upgrades
  • martinjs
    • 3205
    UrS4 ARB upgrades
    Are there any? cant find anything documented?
  • merlin's S4
    • Jan 2005
    • 1539
    Not that I've seen but then the standard ARBs are pretty hefty anyhow.
    • iain1067
      • 984
      you tried whiteline i think they are from the usa
      • martinjs
        • 3205
        They are from Australia, don't list anything for the C4 chassis
        • iain1067
          • 984
          What about the V8 engined cars or do they run the same arb's??
          • martinjs
            • 3205
            Im not sure TBH
            • Rusty
              • 18953
              You could try the dodgy VW trick of doubling up the ARBs. Could work well on the rear.
              • saltinot
                • May 2004
                • 1946
                Look to the avant for thicker roll bars. Avant front bars marked with white, not blue (26mm), are 28mm.
                The rear ARB on the avant is also larger diameter.
                V8 and I5 S4s share the same diameter bars.
                • martinjs
                  • 3205
                  Are they different to the B5 S4's
                  • saltinot
                    • May 2004
                    • 1946
                    B5 is an entirely different animal altogether.
                    • martinjs
                      • 3205
                      The rear B5 ARB fits the S2 avant yes?
                      • saltinot
                        • May 2004
                        • 1946
                        Yes, it does.
                        In the rear only...... The B5 and the B4 saloon/estate share the same suspension geometry. While the part number vary in some cases, they can still be interchanged between the B4 and B5 chassis. BTDT
                        Maybe you were thinking that the urS might have something to offer for the B4 avant? If so, then it does not. However, the urS4/S6 avant does have thicker ARBs that can be used on the all C4 saloons.
                        Does that help explain it better?
                        • martinjs
                          • 3205
                          Ok thanks, guess i'll go looking for some avant bars then (i have a saloon)
