anyone built their own coilover suspension?
  • lind4hl
    • Jul 2008
    • 2465
    as topic, i consider this, to get 2way dampers and can buy universial spring so i can change the stiffness,
    so anyone done this with some info maybe
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    there is a bilstein dealer in Thessaloniki in Greece who i know can do it and i plan to do a coilover set in the future with him.I have a spare set of suspension that can be modified and i plan to send him the set to match it with according springs and bilstein shocks to my liking.
    • Ian Simmonds
      • Jun 2005
      • 2858
      Jay... (Puglife) is doing it for type 85 suspension as we speak.....
      93 MTMS2 Avant
      • Puglife
        • Jun 2006
        • 731
        I used a company called compbrake (believe hamish on the forum used them also) for 2.5" conversion kits (under £30 each) then you just need springs.
        Rallydesign do 2.25" versions which are used on type 85 front struts.
        Hamish has photos of URQ converted struts in his thread, i'll try get some photos in my thread for the rally replica.
        Jay - pug_life85@hotmail.com
        1986 Audi UR quattro - WORK IN PROGRESS
        1981 VW Mk1 Golf - "20v Jim, but not as we know it!"
        • Kieron20V
          • Mar 2008
          • 1505
          Just what your after
          Tutorial NOT FOUND. I would not want anyone thinking that i "have irresistible need to display what you can or what you think you can." also, i want to distance myself from any recourse if you did what i did and it didnt work out for you. because i do something, document it, prove it and run...
          I was considering doing the same with a spare set of struts, but I have located a set that have already been converted.
          1994 URS4 Avant RS2+
          • speeding-g60
            • Aug 2008
            • 1186
            haha. well, i dont have to post the link to what i did then that would be my setup.
            • s2martyn
              Banned
              • Apr 2008
              • 408
              i am also doiung this conversion to my spare struts for the ur .its a pretty straight forward job..what length springs and ratings would be useful info...kits are available from a number of places,compbrake,demon tweeks etc...
              • lind4hl
                • Jul 2008
                • 2465
                speeding g60: awesome, the tops, did they fit with original topmount?
                • G60Rallye
                  • Dec 2006
                  • 1321
                  If you are converting the UR struts then you want the 2.5" kit from compbrake. The sleves that come with them are a perfect fit! Just need to cut the old spring platform off dress the strut down and then weld the sleve in place. The top hat which comes with the kit is also perfect for the job!
                  • lind4hl
                    • Jul 2008
                    • 2465
                    i will convert the oem rs2 strut in the front (m55) and also do the rears, but i have all figured out now
                    thanks for the links and info.
                    i will probably make an guide myself also that i will share!
                    edit: if i want standard height, what spring-lenght should i go for?
                    rear same as oem i understand but front is little diffrent or?
                    • Kieron20V
                      • Mar 2008
                      • 1505
                      Well with coilover struts the ride height is dependant on where you adjust the spring perch no? I thought that was the whole idea?
                      • lind4hl
                        • Jul 2008
                        • 2465
                        yes that´s right, but i dont mean lengt by 10mm an est. lenght, cause i think the spring must be shorter then oem on the front, but yes you can adjust really much
                        • s2martyn
                          Banned
                          • Apr 2008
                          • 408
                          did you get spring length sorted??
                          i have ordered 8" long springs as recomended by a few...will post pics of ride height when complete...strut housing is very easy to convert
                          • Puglife
                            • Jun 2006
                            • 731
                            for type 85 i went for 9"x 2.5" springs front and rear... you have to take into account spring rates and lengths, a softer spring will compress more, so you need to work out stock length of a compressed spring at stock ride height. Then work out the same for different spring rates and work out the right length, but as said if you get them slightly longer than necessary you can always adjust the spring pan to suit
                            • s2martyn
                              Banned
                              • Apr 2008
                              • 408
                              what kind of ride height are you at then now?close to standard?and how far up the threaded body are the locking collars?i was also told that i could use 7" springs,but thought better of it
                              also spring rates are 450lb front and 550lb rear,i was also told that for track only use 550 front and 650 rears and i have used bilstein inserts with the blue anodised locking top mounts with sherical bearings
