anyone built their own coilover suspension?
  • Settari
    • Jan 2011
    • 69
    Can you say, are those the same sleeves as what they still sell? Material is aluminium and id 54.22mm?
    • Maxx
      • Mar 2018
      • 1
      • Country: Belarus
      #32
      Hi everyone.
      could someone please advise which KW HAS will fit a200 20v (same as s4/s6 c4). They have no dimensions specified and do not offer anything from HAS if the model is selected. I have Koni shocks.
      Welcome to KW suspensions! With us you will find a suspension solution for every use ➤ Whether road, trackday or professional motorsport!
      Thanks!
      Max.
      • Thuppu
        • 4115
        One 55mm sleeve kit: https://www.adenstyres.co.nz/product...nt=30750131020
        • Settari
          • Jan 2011
          • 69
          Now I can confirm that the compbrake sleeve kit is suitable for a S2 55mm struts. Only if you use the original top bearing, need to put the bush above on the top cap. Sleeve inside diameter is 55.3mm and material is steel.
          This gallery has 1 photos.
