I won't be paying all that much (I'll steal it from my other car) <: and then just bid my time until I find another one <:
I've had servotronic unplugged for years so that does NOT matter <; OR is there something related to servotronic/the steering rack that I need to remove while changing/fitting the new steering rack?
EDIT: yeah, I found in ETKA that both ABY and ADU is 895 422 065 C !
EDIT2: Error404: does the ABC (2.6) and/or AAH (2.8) steering rack have servotronic or not? or are they also the same as ABY/ADU?
One more question <: how do you remove the steering rack from the car?
ABY:
I've removed 4x 17mm nuts on the left/middle
I've removed 2x 6mm hex bolts through the wheel housing
I've removed 2x 19mm banjos on the rack itself
It's loose but I can't pull it out yet.. have I forgotten/missed any nuts/bolts? how do I proceed?
3B:
Haven't begun yet, want to know a little bit more in advance!
1. what should be removed in preparation?
2. is the servotronic just a plug/loom to remove?
3. any tips on what path you remove the rack through? up? down? etc
The control arm on the rack also needs freeing as it is attached to the steering column, its inside the car just behind the bulk head.
Its an incredibly difficult task to remove the rack with the engine in place.
I not as easy as Up/Down. Just free it up and start to move it, you'll find the best path once its lose.
You dont have to remove the servo loom. Just unplug it under the rear seats and on the rack.
Well well, we are there ladies and gents.. its time for the maaaaain event of the evening.. fitting the ABY steering rack to the 3B coupeeeeeeee
Anyways, I read about some restrictor valve something something.. is there something that I need to do besides draining the hydro fluid, removing the 3B steering rack + servotronic loom before fitting the ABY steering rack?
