Steering Rack On 3b To Replace
  • audimaniac
    • Feb 2007
    • 152
    Hi Guys
    I have searched and searched but cannot find what i need, i have two questions for you.
    First one is, Will an RS2 Steering Rack fit a 3B Coupe???
    Second one is, Will the aby 6 Speed Gearbox fit the 3B Engine, eg mating up etc??
    Thanks in advance guys.
  • s2driveruk
    • 12696
    rs2 rack into a 3b is YES...just need to delete the servotronic as the ADU rack doesnt have a plug for it...BTDT
    1992 3b S2 Coupe
    • Andreas
      • Nov 2005
      • 731
      does the ABY steering rack fit the 3b coupe as well?
      Andreas Lundstroem
      A4 STCC Avant -04
      Audi /S/2/ Sedan -94
      prev.
      Audi /S/2/ Coupe -91
      • s2_bo
        • Oct 2005
        • 6067
        Yes but you wont be able to use pervotronic.
        IIRC ABY and ADU racks are the same.
        91 S2 coupé - RIP
        98 S8 - Luxury barge
          same rack as the ABC (2.6) and AAH (2.8) engined coupes too so don't got paying over the odds just cos its from an S or an RS
          • Andreas
            • Nov 2005
            • 731
            I won't be paying all that much (I'll steal it from my other car) <: and then just bid my time until I find another one <:
            I've had servotronic unplugged for years so that does NOT matter <; OR is there something related to servotronic/the steering rack that I need to remove while changing/fitting the new steering rack?
            EDIT: yeah, I found in ETKA that both ABY and ADU is 895 422 065 C !
            EDIT2: Error404: does the ABC (2.6) and/or AAH (2.8) steering rack have servotronic or not? or are they also the same as ABY/ADU?
            Andreas Lundstroem
            A4 STCC Avant -04
            prev.
              Ah just realised you are LHD
              Not sure if the LHD racks are the same for the ABY / ADU and the V6 engined cars - for RHD they are the same
              • Andreas
                • Nov 2005
                • 731
                aaaa, okay <: I'm gonna check with the swedish dudes at nordicaudi then! thanks anyways mate!
                EDIT: is there something that I need to remove from the old rack? some servotronic kit?
                Andreas Lundstroem
                A4 STCC Avant -04
                prev.
                • s2driveruk
                  • 12696
                  no just pull the lead from the rack and also from the control unit under the seat
                  1992 3b S2 Coupe
                  • Andreas
                    • Nov 2005
                    • 731
                    Golden!
                    Andreas Lundstroem
                    A4 STCC Avant -04
                    prev.
                    • Andreas
                      • Nov 2005
                      • 731
                      One more question <: how do you remove the steering rack from the car?
                      ABY:
                      I've removed 4x 17mm nuts on the left/middle
                      I've removed 2x 6mm hex bolts through the wheel housing
                      I've removed 2x 19mm banjos on the rack itself
                      It's loose but I can't pull it out yet.. have I forgotten/missed any nuts/bolts? how do I proceed?
                      3B:
                      Haven't begun yet, want to know a little bit more in advance!
                      1. what should be removed in preparation?
                      2. is the servotronic just a plug/loom to remove?
                      3. any tips on what path you remove the rack through? up? down? etc
                      //Andreas
                      Andreas Lundstroem
                      A4 STCC Avant -04
                      prev.
                      • s2_bo
                        • Oct 2005
                        • 6067
                        The control arm on the rack also needs freeing as it is attached to the steering column, its inside the car just behind the bulk head.
                        Its an incredibly difficult task to remove the rack with the engine in place.
                        I not as easy as Up/Down. Just free it up and start to move it, you'll find the best path once its lose.
                        You dont have to remove the servo loom. Just unplug it under the rear seats and on the rack.
                        Job done
                        Good luck
                        91 S2 coupé - RIP
                        • Andreas
                          • Nov 2005
                          • 731
                          Well well, we are there ladies and gents.. its time for the maaaaain event of the evening.. fitting the ABY steering rack to the 3B coupeeeeeeee
                          Anyways, I read about some restrictor valve something something.. is there something that I need to do besides draining the hydro fluid, removing the 3B steering rack + servotronic loom before fitting the ABY steering rack?
                          Anything at all?
                          Or, like Nike says, just do it?
                          //Andreas
                          Andreas Lundstroem
                          A4 STCC Avant -04
                          prev.
                          • lind4hl
                            • Jul 2008
                            • 2465
                            and use V.A.G oil in the rack and _nothing_ else!
                            • Andreas
                              • Nov 2005
                              • 731
                              I am (; dont worry (:
                              Andreas Lundstroem
                              A4 STCC Avant -04
                              prev.
