has all audi 80 same steering rack
  • lind4hl
    • Jul 2008
    • 2465
    as topic, is all 80´s having same steering rack? i might buy one and attempt to do an steering rack with shorter left-> right
  • anton
    • Jan 2005
    • 802
    no, they are different, the coupe is about 3.2 at least my cq20v is and i know the ABY is 2.6. this is why i put it in mine there may well be others i'm not sure
    Ant
    91' Coupe quattro 20v - project
    KW V2s and other goodies
    now gone
    03' BMW 330CI - Sold
    08' A5 Coupe 3.0l tdi quattro - Sold
    57' BMW 525d M Sport Touring
    • lind4hl
      • Jul 2008
      • 2465
      ok, but the same housing then? cause i will change the parts inside..
      edit: i will probably buy and audi 80 housing, compare and then remake it to shorter steering
      when i have time of course
      • sam80quattro
        • Oct 2006
        • 1496
        i put a rack(including track rod ends etc) from my b3 coupe into a b4 saloon if that helps. fit perfectly
        • anton
          • Jan 2005
          • 802
          the two racks i changed, thats 20v cq and aby s2 avant looked the same to me, didnt study them too closely tho....i'd be surprised if the 3b rack was interchangable tho since thats the servotronic rack......
          Ant
          now gone
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            The pinion part of the Servotronic rack is definitely different.
            SS
            • mcandmar
              • Apr 2004
              • 5118
              Anton is spot on with the specs, they look identical so i would be surprised if you couldn't swap the internals over.
              7A CQ 20v
              Turns (lock-to-lock): 3.2
              Turning circle (curb-to-curb): 36.4'/11.1m
              Ratio: 16.8:1
              S2 ABY
              Turns (lock-to-lock): 2.7
              Ratio: 14.5:1
              91CQ20v - Gone to a new home
              93UR-S4 - The Magic Carpet
              94S2Bus - The Emerald Express
