Poly Bushes - Avant
  • Big Lee M
    replied
    Sorry totally forgot about this,the part number for the rear lower arm bush from Powerflex is PFR3-206
    Hope this helps
  • M_GORDON
    replied
    HI!
    I have too a avant and I must change all pieces (I don“t change they).
    I see 034 motorsport sell some of Powerflex to our cars, but they do sell all in one packet?
    THX
  • madpugger
    replied
    You did? Oh i must have been stopped to eat a BK!
    I haven't seen an S2 for aaaages!
  • istoo
    replied
    totally OT
    saw you parked up at the beach a few weeks ago... waved but thought it was rather pointless given you would have no idea who i was!
    Spied a huge increase in S2's lately around the shire.
  • madpugger
    replied
    Ok, on the rear there is a lower wishbone, an upper wishbone and the hub carrier.
    Lower wishbone has:
    Front inner bush
    Rear inner bush
    Shock absorber mounting
    Hub carrier mounting on the outer (This is the bush not listed as far as i can see - the bush is actually in the bottom of the hub carrier)
    Upper wishbone:
    Inner front and rear bushes (the same as each other)
    Outer bush where the hub carrier is bolted to it (above the wheel)
    Hub carrier:
    This has one bush at the bottom, where it connects to the lower wishbone. (again, this is the bush I am after) It is the one that has the camber adjust bolt through it.
    It also has the mounting for the ARB Drop Link.
  • Flat on my back
    replied
    Well...
    there's a thing...search for threads by Skull (you'll need 2 dots over the 'u').
    He's trying to get some PU ones made...
    Or you talking about the smaller arm that comes off the cast arm? (sets the rear toe).
    Balljoint...that's got me confuzed...we need a piccy.
  • madpugger
    replied
    Yeah, where a ball joint would be on the front.
  • Flat on my back
    replied
    You mean the large bush in the 's' shaped cast arm, then no.
  • Big Lee M
    replied
    I've got a full bush set to fit front and rear I'll get the part number when I get home tonight.
  • madpugger
    started a topic Poly Bushes - Avant
    Poly Bushes - Avant
    Does anyone know, do powerflex do the rear lower wishbone outer bush?
    I called them and they 'said' they do them, but I don't see them listed so I wandered if anyone has fitted them?
    Mike
