Eventually got the RS2 Rack fitted in the car, what a Ba-----d!!! do you know what the pipe coming down from the brake fluid resevoir is supposed to do?? it joins into the return pipe to the power steering resevoir.
The RS2 rack has a restrictor valve in one of the union banjo bolts, when i got the rack the union with the restrictor in was on the hose to the power stg pump, does that sound right??
Thanks in advance David.
