I think i know the problem but cant find any mention on the forum.
I bought a powerflex bushing kit for the avant and the rear upper a-arm bushings dont seem to fit. I've discovered there are two versions of the a-arms, either a solid cast piece or a pressed steel one welded together. Audi book lists two different bushings so i assume the bushings i have are for the pressed steel versions.
Question is has anybody tried to modify the bushings to fit, or know where i can buy poly bushings for these arms?
I think it might be possible to cut the bushing and sleeve down to size, have to measure up the bolt through the middle to confirm though. Any BTDT's?
Cheers, Mark.
Cheers, Mark.
