s2 central, i could not get the upper a-arms bolt out when this was bolted to the car. so you need to take the whole package out.
Potential GB - Powerflex missing bushes
Well if you can remove the top of strut/damper without messing with upper wishbones that would be even better... Saves the need to disconnect lower fixing on strut as well
Cool - thats even easier then... rusty bolts permitting !Paul Nugent
You obviously have never tried to take a B4 rear end apartWith a big enough hammer, you'll be done by lunchtime
Seriously though --->
1. Disconnect prop & probably need to get the zorst out of the way too
2. Slacken forward diff mount where it connects onto chassis
3. Remove handbrake cables and Remove flexible brake lines
4. Unbolt upper wishbone inner mounts to the top of strut/damper
5. Unbolt dampers from where they connect to lower wishbones
6. Remove the four subframe bolts with it all secured on a jack to drop all as one
Easy to say innit !!!
As lind4hl says shock/spring/upper arm has to come out in one piece, actually not that bad of a job. Its the lower arms, camber adjustment bolts, and brake lines that will drive you insane with rage!91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald ExpressComment
How come the only peeps chatting on this thread are very far away?
Less chatty boys and more volunteers...
Carlos.
On the look out for less bits for my s2 saloon project. Now supporting myself by shooting for my food. www.airgunforum.co.ukComment
mcandmar: no need to take away lower wishbones, just drop the whole thing, much easier, and let powerflex do the rest of the job
as i said in order:
prob-bolts
there is an joint ( not the smoke type
) 20cm in front of the subframe on the brake line, release this.
cut/ let go of the handbrake cables
4 bolts in the upper suspension parts that hold the whole ting to the chassis, NOTE do not just let it go, support it so you dont get any dents in the fender. ( upper a-arms hit the inside of the fender)
then last the 4 subframe bolts.
tadaaa
One thing i've learned we are way behind the Scandinavians!Comment
Has anyone managed to pass this info on to other forums to increase interest?Comment
Work so far done.
I now have the osr suspension unit off as well as the drive shaft...most of the nsr is also done.
Sorry it's taking some time as i can only do about 2 hours before my hayfever shuts my breathing down...
Hth.Carlos.
And for those who need piccies...
Exhaust is out of the way so next job is to take the diff off without breaking it or me...then the subframe.Attached FilesLast edited by Flat on my back; 25 June 2009, 15:07.Carlos.
Good work CarlosPaul Nugent
