Potential GB - Powerflex missing bushes
  • Flat on my back
    • Jan 2007
    • 2449
    Right...
    Next is the diff...what else apart from the obvious front/rear mounts needs to be disconnected, eg wiring or vacuum lines?
    Carlos.
    • madpugger
      • Sep 2007
      • 1901
      Sorry I am offshore so am of no help!
      Has anyone had any feedback from B5 or other B4q owners on other forums yet?
      Le Mans 2012
      Nurburgring 700
      1995 S2 Avant
      • lind4hl
        • Jul 2008
        • 2465
        2 vacuum hoses and 1 cable on the passangerside of the car, @the back
        • Flat on my back
          • Jan 2007
          • 2449
          We have lift off...
          News is the diff and subframe are now off and ready to go...to Powerflex.
          Really not quite sure the whole lot will fit into my poor old 90?
          Anyone able to help with the delivery?
          Carlos.
            #110
            I can't help here Carlos, but I'm happy to be a guinea pig on the upper wishbone bushes - cast variety - do we have any clue when samples might appear ?
            • Flat on my back
              • Jan 2007
              • 2449
              Not sure who has been in contact with PF.
              Need them to PM me so we can have a chat...
              Where are PF exackerly?
              Carlos.
                #112
                Can I be so bold to ask that the upper wishbone bushes get looked at first - for cast applications - the feeling I'm getting is that the inner bushes have same diameter as used on pressed arms, but they need to be shorter in length for a nice fit in the cast arm... To be confirmed of course - Would be a very easy tweak for PF if that is the case to productise such a variant.
                • lind4hl
                  • Jul 2008
                  • 2465
                  Much cred to you Flat_on_my_back! great work
                  • Flat on my back
                    • Jan 2007
                    • 2449
                    I beleve that is correct.
                    Carlos.
                    • lind4hl
                      • Jul 2008
                      • 2465
                      send a pm to madpugger though, but i think he will look in his thread
                      • Flat on my back
                        • Jan 2007
                        • 2449
                        Off the top of my head...
                        RS246,
                        Audifans.net,
                        Club-Audi
                        Who else needs to be contacted?
                        Carlos.
                        • Skull
                          • 3506
                          • Country: Slovenia
                          #117
                          AndersS2 has done this! I could not remember who did it, came to my mind today.
                          Audi Quattro WR
                          • madpugger
                            • Sep 2007
                            • 1901
                            Carlos, got your PM ta
                            Good work!
                            I will give you a call tonight hopefully, once I have finished work. And I will try and call PF tomorrow.
                            My mate with an RS4 has said he will bring the topic up on the forum he uses, but no idea if he has or which one it is.
                            Le Mans 2012
                            Nurburgring 700
                            1995 S2 Avant
                            • mcandmar
                              • Apr 2004
                              • 5118
                              See here for pic http://www.s2forum.com/forum/showthread.php?t=37633, and here http://www.s2forum.com/forum/showpos...&postcount=439 for Anders solution. Also worth noting early cast arms have a 180mm bolt, later pressed arms have a 212mm bolt. I'm working on the basis you can shorten the bushing, centre sleeve, and use the later 208mm bolts. ....to be confirmed of course
                              91CQ20v - Gone to a new home
                              93UR-S4 - The Magic Carpet
                              94S2Bus - The Emerald Express
                              • madpugger
                                • Sep 2007
                                • 1901
                                Or Powerflex could make us the correct bushes
                                Le Mans 2012
                                Nurburgring 700
                                1995 S2 Avant
