I am looking for some opinion, for this king of tyres, hoosier, or MT , and also some sugestion related to size. Car is a b4 sedan, about 1150 kg.
Drag tyres
Centerline Convo-pro rims. 7.5" front and 8.5" rear. i went with this rim as it is really lightweight. less rotating mass, weight, etc.
tires were matched to within 1/4" rollout by John @ M&H personally, due to the all-wheel drive setup.
the Backspacing of the rims are 5". 4 x 4.25" (which is 4 x 107.95mm close enough).
and these are actual wrinkle wall slicks. offroad or drag use only.
and i do use MT's on my FWD drag rabbit, 24.5" X 9" / 13's....
http://www.mandhtires.com/store.php?...on=show_detail
MH and MT (M/T) are separate companies.
http://mickeythompsontires.com/
SpeedingGdude speaks of Mickey Thompsons and has MH Racemasters in the pics.Everything less than 2 bar is considered to be naturally aspirated
So you use mt's on your mk1, golf do you have any 60ft times?
And what 60ft times are you expecting in your coupe with the mh tyres.
I'm just curious because im about to buy some slicks for mineThe ONLY S2 Golf!
10.42@138mph
Originally posted by repo View PostMH and MT (M/T) are separate companies. OF COURSE THEY ARE!
SpeedingGdude speaks of Mickey Thompsons on his DRAG RABBIT and has MH Racemasters ON HIS DRAG COUPE in the pics.
i have two drag chassis. neither of which are at the levels that you do, but mine are just my own projects that i built myself in my garage at home. sorry i was being confusing or vague....
Originally posted by gnutz2 View PostSo you use mt's on your mk1, golf do you have any 60ft times? 24.5 x 9 / 13's on the MK1. 1.72 is best to date. that car spins all the way down the track. i do finally hook in 3rd, but still blow it off.... i cross the 1/4 mile @ ~130 mph still spinning....
And what 60ft times are you expecting in your coupe with the mh tyres. i would like to see ~1.5's...
I'm just curious because im about to buy some slicks for mine [b] i have found that many of my friends that race prefer MT for the 13" sized stuff in the 24.5's, so thats what i went with there. for the coupe i went with the size i wanted and chose M&H as they are a little bit wider contact patch for the same size tire. not that i know anything about this stuff....
Sorry, didn't want to upset anybody, just that not all know these brands.
Tomi has 10.5-26.5-15 M/T ET Streets in the red coupe, and the best 60ft has been 1,28.
In RS he has same front tyres as in the red one, but 11.5-26.5-15 ET Streets at the rear, and so far the best 60ft has been 1.26.
Yes, DOT tyres.Everything less than 2 bar is considered to be naturally aspirated
My best is 1.79 on just normal road tyres so i was hoping for 1.5 60ft with slicks.
I think knocking off .2 seconds is reasonable.
What are DOT tyres?The ONLY S2 Golf!
10.42@138mph
Up now I understood that the coupe uses DOT tires, 1.26s on glued track. My problem is that we don't have glued track, so my best time will by 0.3s slower.
Have any one tried drag tires? Like the MH on the pics above.
Why chose DOT (radial) tires in stead of drag (diagonal) tires on an AWD car?
