Drag tyres
  • vcosmin
    • Apr 2008
    • 644
    • Country: Romania
    Drag tyres
    I am looking for some opinion, for this king of tyres, hoosier, or MT , and also some sugestion related to size. Car is a b4 sedan, about 1150 kg.
  • speeding-g60
    • Aug 2008
    • 1186
    posted on MG, but here ya go.
    MT!!! 24.5 x 8.5 / 15 on a 7.5" front and 8.5" rear.
    • vcosmin
      • Apr 2008
      • 644
      • Country: Romania
      This tyres, did require some modification of body work ?
      LE. it seems that you are using some kind of drag rims ? any advantages over stock ones ?
      • AUDIS2avant
        • Jan 2009
        • 670
        • Country: Denmark
        As long as they are real drag tyres without side armour, then fine.
        But people seem to perfer M/T tho
        • speeding-g60
          • Aug 2008
          • 1186
          Centerline Convo-pro rims. 7.5" front and 8.5" rear. i went with this rim as it is really lightweight. less rotating mass, weight, etc.
          tires were matched to within 1/4" rollout by John @ M&H personally, due to the all-wheel drive setup.
          the Backspacing of the rims are 5". 4 x 4.25" (which is 4 x 107.95mm close enough).
          and these are actual wrinkle wall slicks. offroad or drag use only.
          and i do use MT's on my FWD drag rabbit, 24.5" X 9" / 13's....
          • repo
            • Dec 2004
            • 893
            MH and MT (M/T) are separate companies.
            Mickey Thompson Tires & Wheels – UNDISPUTED.
            SpeedingGdude speaks of Mickey Thompsons and has MH Racemasters in the pics.
            • gnutz2
              • Aug 2006
              • 928
              So you use mt's on your mk1, golf do you have any 60ft times?
              And what 60ft times are you expecting in your coupe with the mh tyres.
              I'm just curious because im about to buy some slicks for mine
              The ONLY S2 Golf!
              http://www.s2forum.com/forum/showthread.php?t=19402
              10.42@138mph
              https://m.youtube.com/watch?v=0wnkkOfFpXg
              • speeding-g60
                • Aug 2008
                • 1186
                Originally posted by repo
                MH and MT (M/T) are separate companies. OF COURSE THEY ARE!
                SpeedingGdude speaks of Mickey Thompsons on his DRAG RABBIT and has MH Racemasters ON HIS DRAG COUPE in the pics.
                sorry, i didnt think anyone wanted to see about the FWD car.....
                i have two drag chassis. neither of which are at the levels that you do, but mine are just my own projects that i built myself in my garage at home. sorry i was being confusing or vague....
                Originally posted by gnutz2
                So you use mt's on your mk1, golf do you have any 60ft times? 24.5 x 9 / 13's on the MK1. 1.72 is best to date. that car spins all the way down the track. i do finally hook in 3rd, but still blow it off.... i cross the 1/4 mile @ ~130 mph still spinning....
                And what 60ft times are you expecting in your coupe with the mh tyres. i would like to see ~1.5's...
                I'm just curious because im about to buy some slicks for mine [b] i have found that many of my friends that race prefer MT for the 13" sized stuff in the 24.5's, so thats what i went with there. for the coupe i went with the size i wanted and chose M&H as they are a little bit wider contact patch for the same size tire. not that i know anything about this stuff....
                • repo
                  • Dec 2004
                  • 893
                  Sorry, didn't want to upset anybody, just that not all know these brands.
                  Tomi has 10.5-26.5-15 M/T ET Streets in the red coupe, and the best 60ft has been 1,28.
                  In RS he has same front tyres as in the red one, but 11.5-26.5-15 ET Streets at the rear, and so far the best 60ft has been 1.26.
                  Yes, DOT tyres.
                  • speeding-g60
                    • Aug 2008
                    • 1186
                    and that is bad *** times for street DOT tires, as well.... if i got 1.4's that would be the cool stuff for me.
                    • gnutz2
                      • Aug 2006
                      • 928
                      My best is 1.79 on just normal road tyres so i was hoping for 1.5 60ft with slicks.
                      I think knocking off .2 seconds is reasonable.
                      What are DOT tyres?
                      The ONLY S2 Golf!
                      10.42@138mph
                      • repo
                        • Dec 2004
                        • 893
                        Street legal.
                        Your car is awd right? With ET streets I see no reason why You shouldn't be able to hit 1.3's on glued strip.
                        • vcosmin
                          • Apr 2008
                          • 644
                          • Country: Romania
                          Up now I understood that the coupe uses DOT tires, 1.26s on glued track. My problem is that we don't have glued track, so my best time will by 0.3s slower.
                          Have any one tried drag tires? Like the MH on the pics above.
                          Why chose DOT (radial) tires in stead of drag (diagonal) tires on an AWD car?
                          • repo
                            • Dec 2004
                            • 893
                            both cars meet streetcar regulations with original lights, side blinkers and stuff. In street class we are obligated to use street tyres.
                            • vcosmin
                              • Apr 2008
                              • 644
                              • Country: Romania
                              I'll probably buy 4 DOT M/T an a pair of drag slick for races where the regulation allows it.
                              Which drag slicks need no burn out?
