So i've got a bit of a dilema thats a little bit different to most suspension queries on here!
My dagdag is currently in the process of quite an extreme makeover, and included in this is the fitting of air ride! this obviously involves replacing the springs with a rubber bag which can raise the ride height of the car via a switch on the dash. I had wanted to go coilovers to get it running really low, but the speedbumps where i live dictate i need to be able to clear them, so adjustable height was called for! :mischeif:
So as the plan is to have the car as low as it will possibly go when the parked, i have taken out the springs, and adjusted the arches to fit the wheels accordingly. My problem now is that the front suspension wont sit as low as the rear, making the car sit about 1 inch higher at the front compared to the back. (see pic)
In order to keep up with the vw boys at the likes of edition38, the car needs to ideally have the same arch gap all round, or sight lower at the front (known as rake). So to achieve the perfect stance, what are my options for making the strut/strut housing shorter? in that pic, the top mount is touching the shortened bumpstop!
from reading on here, it would seem that the coupe quattro rear strut is approx 15mm lower than the fronts. Im wondering if it would be worth getting all the brackets and steering arm cut off my front struts and welded onto a pair of rear coupe quattro struts? Or has anyone any other thoughts?
(incase anyone was wondering, the wheels are BBS RS splits 7.5x16 front 8.5x16 rear et 35 with a 15mm spacer all round. wrapped in 195/45 16 toyo proxes)
