Balljoints.
  • martinjs
    • 3205
    Balljoints.
    I started on changing all my wishbone bushes yesterday, and decided to renew all the balljoints whilst im there, the rubber boots on the rears had split. So ive ordered some from ecp. Anyway before i order some for the front was wondering if there is 2 types for forged and pressed w/bones? ive got forged fronts.
    cheers
    martin
  • Stick Insect
    • Dec 2003
    • 2338
    cheers
    martin
    Martin they seem to be the same part number for both.
    Don't forget to get your tracking done!
    • martinjs
      • 3205
      Yeah, did see that on etka, on the list of parts on vagparts site they have 4 listed in total for the front, doesnt state part numbers though.
      When its all done i'll get all the alignment checked.
      • quattro4Life
        • 92
        a good tip for when youre changing them.....before you remove the old joint....take some chalk or white-out, and mark the bracket where it lines up with the end of the control arm. then mark the same line along the new one, and install it so that line meets the control arm the same as the old one, and it will help keep your alignment as close to how it was beforehand.
        -b
        Im not the percent you think survives,
        I need sanctuary in the pages of this book...
        • Martynf
          • 1885
          Hi Martin how you doing?
          The two arms, forged and pressed, they do not have the same parts.
          Here's the low down on both:
          The forged arms:
          Balljoint LH side: 895 407 365A
          Balljoint RH side: 895 407 366A
          Wishbone bushes: 893 407 181 x4 in total
          The pressed arms:
          Balljoint LH side: 8A0 407 365
          Balljoint RH side: 8A0 407 366
          Wishbone bushes: 8A0 407 181 x4 in total
          Completely ignore any parts listing that says X type is fitted to X year etc. You have to look at what arm you have fitted, then get the parts to match.
          HTH
          Martyn
          Martyn
          www.vagparts.com
          • martinjs
            • 3205
            Im ok martyn thanks, thanks for the numbers.
            took the front arms off today and can see how different they are.
            you may be getting a call from me tomorrow then.
            thanks
            martin
            • Martynf
              • 1885
              no worries!!
              My car should not have forged arms on it by chassis number, unyet it has got them fitted!!!
              Martyn
              thanks
              martin
              Martyn
              www.vagparts.com
              • martinjs
                • 3205
                so should the early 3b's (mine) have pressed fronts?
                are the rears all pressed on all models?
                confusing or what!!
                martin
                • Martynf
                  • 1885
                  just no way of being sure Martin! not on the fronts! all the rears are pressed as far as I'm aware ( i bet someone has fitted aluminium fronts on the back though!)
                  WELL confusing this one!!
                  Not as bad as A3 seat base side plastic trims though!! but thats another story!!
                  Martyn
                  Martyn
                  www.vagparts.com
                    The forged arms:
                    The pressed arms:
                    HTH
                    Martyn
                    Ah thanks to Martyn I knew this be on here somewhere
                    • s2driveruk
                      • 12696
                      anybody heard from Martyn since the start of the year, he's missed around this place!
                      1992 3b S2 Coupe
