A couple of questions I have had my s2 1991 coupe
parked up for 3 weeks on a hill and now the red warning light is lit and there is a noise when the steering is turned sounds like low hydraulic pressure.I have checked the level and when you pull the sensor out you can just see the fluid. There is oil leaking (not dripping) lower passangers side running on to the subframe mounts I cant see where its coming from.what oil do I use to top up?
Help as MOT due Friday and I guess it will fail with the noise and light on!!
parked up for 3 weeks on a hill and now the red warning light is lit and there is a noise when the steering is turned sounds like low hydraulic pressure.I have checked the level and when you pull the sensor out you can just see the fluid. There is oil leaking (not dripping) lower passangers side running on to the subframe mounts I cant see where its coming from.what oil do I use to top up?Help as MOT due Friday and I guess it will fail with the noise and light on!!
