K24R - Standard rideheight spring options
    Is there an interestest in stock rideheight, uprated springs? This will maintain better suspension geometry. I might do a token effort and drop it 5mm
    And, is there an interest in replacement springs for the rear that adjust rideheight for weight removal, thus removing the need for coilovers?
  • Lago Blue
    • Jul 2009
    • 843
    I think that your front spring idea is eminentely sensible. The longer I keep my B3 Q Coupe, the more I raise the front end, and the more I like it. The next spring I'll wan't to try will be as you describe.
    I would be interested to know what all the various springs (OEM & non) that fit stock perches are in terms of rate.
    Your rear spring idea, is also interesting, but because I'm curious to hear you explain how that would work. Are you trying to keep the rear half of the body down (like when it is fully loaded) when it's lightly loaded?
    • A80Avant
      • 10873
      • Country: Greece
      next year i will try out my modified rs2 springs that i had lowered by 15mm instead of the HRs. i hope they do the job!
        The rear spring is to counter the body rise when you strip the rear interior out and thus reduce the rear axle load by 50-100kg. The springs would be designed to complement whatever front spring was used, so as to keep the handling correct. I've got to the quote stage with this and can custom specify springs and have them manufactured. There was no intrested so I shelved it for now.
        • iDub
          • Oct 2006
          • 182
          I'd be interested depending on price. Mine's too low with the h&r's on. I think a 10-15mm drop would be a better compromise in terms of balancing suspension geometry against reduced centre of gravity (and looks obviously )
          Audi S2:
          Avant! Ye scurvy landlubber...
            HnRs are a 20mm drop from my measurements on the Coupe.
            Price is looking like the same as Coupe HnRs, £250 a set but that's just a ballpark at the mo.
            For the Avant, I'll need some rear springs to look at and to get the rear spring length when the car is stationary, preferrably stock springs and the maximum length of the spring when off the car and on the damper, will do the same on the coupe too. The companies I've been speaking to can test spring rates and can do HnResque variable rate springs in case such a thing is needed to sort the free length out, as HnR have done.
            • iDub
              • Oct 2006
              • 182
              I assume the coupe is lower than the avant as standard then. Mine seems really low on the h&r's!
              I've got a complete set of standard avant suspension you could use for measurements etc if it helps. It's in a box in my shed!
              Audi S2:
              • iDub
                • Oct 2006
                • 182
                Double post...
                Audi S2:
                  I don't remember seeing any coparisons between avant and coupe.
                  My coupe on 225/45r17 sits 660mm stock and 640mm HnR, that's along the centre line of the hub to the wheel arch. Be interested in how the avant sits.
