Tie Rod adjusters
  • bambridge
    • May 2009
    • 609
    Originally posted by Audi Parts Guru
    It's a shame that the part where you put the spanner on isn't a bit bigger, IE 17mm. The standard ones are only 14mm from memory, and they are prone to rounding off
    The reason they use 14mm A/F instead of 17mm A/F is all done to cost, the smaller material is cheaper and quicker to machine, so will cost less?
    Soon as i get the sample, i will get some prices sorted
    As AndyP said there £6-00 each?
    Yet if there mass produced, there probadly cost less than £2-00 each to produce.
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      many thanks for that. i have ordered the tape and tell them to use it on the areas that will be rust prone
