Coilovers election
  • MarT2
    • 175
    • Country: Spain
    Coilovers election
    What do you think that it's better, independment of the price?
    11
    KW v1
    0.00%
    0
    KW v3
    63.64%
    7
    H&R RSS ClubSport
    36.36%
    4
    The poll is expired.
    Depends what you're after, no point going all adjustable on a road car that goes to the shops and back... do you use it on track?
    • quattro
      • Dec 2004
      • 768
      The problem is how many owners have had all 3 so they can compare???? not many i asume!
      Probably the longet S2 project in history EVER!
      • Avanter
        • Nov 2008
        • 35
        • Country: Latvia
        For road and some tarmac track days i vote for KW Ver 3... but after KW spring change to H&R or Eibach.
        • G60Rallye
          • Dec 2006
          • 1321
          I used to run H&R's and then KW v3's on my Rallye and thought the KW's were far better. They were a brilliant set up and soaked up the bumps nicely as well unlike a lot of coilovers.
            What spring rates used G60Rallye - on an S2 or something else ?
              There's also the Mance CCK kit that you use to convert your current struts and then choose all the other bits like spring rates and dampers.
              • quattro
                • Dec 2004
                • 768
                Ye i did that its ok but not quite the same as a proper kit!
                • lind4hl
                  • Jul 2008
                  • 2465
                  if im not remeber wrong kw coilovers has 80N/mm front, rears i dont know..
                  • s2_bo
                    • Oct 2005
                    • 6067
                    I'm using a coilover kit from Mance with front Urs4 Bilstein dampers, Eibach #400 springs and race spec Promounts all round.
                    Very stiff, not ideal for a lot of bumpy road/ lane use but you get used to it... The grip is very impressive.
                    91 S2 coupé - RIP
                    98 S8 - Luxury barge
                    • gavs20v
                      • Sep 2004
                      • 3057
                      2nded on the kw's. i had a kit built for the cab s2 cab. With the s2 kit you can specify slightly stiffer spring rates when you order as an option
                      Gav
                      S2 Cabriolet.........
                      • re2500
                        • May 2007
                        • 2185
                        Whats wrong with KW v2's I'll be fitting these to my coupe soon!
                        "Difficult is worth doing"
