Anybody tried these cheap springs on eBay? Any good or avoid at all costs? Are there any reasonably priced (i.e sub £250) sets of coilovers available for a quattro Coupe?
Lowering springs
Not heard of anyone running those springs, but I don't expect their up to much.
A new set of quailty coil-overs is going to be the thick end of a grand.
My advice would be to go for H&R springs with either Koni dampers or Billy's if you budget allows for them.1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS. -
S2 is much heavier than a 2.0
You'll get a corner for £250, afraid you've chosen the wrong car for reasonably priced parts, these aren't Golfs or Polos, in fact you can buy a Golf or Polo for the cost of most upgrades, my front brakes used to be a mk.2 GTI for example
1994 ABY Coupe - Projekt AlpinweissComment
Is it an S2? Says CQ in the top thread, it might have been a little early for me to read and compute...
Stick with HnR or Eibach for a CQ, they'll not be too much money, dampers will be cheaper than an S2 too, still looking at £500 for a basic setup or £750 for KW coilovers unless you get lucky secondhand.Cheers'en, AndyC
Link changed to relevant product
It's a 2.8 V6 CQ
Gotta be better than chopping the springs I have, right? I couldn't justify spending £500+ on suspension just at the minute, especially since the car was only £565 in the first place!
I'm sure it'll be as cheap as my Golf (ok maybe not SO cheap that I usually end up in profit
) if I look in the right places
What I need really is a forum full of idiots - the Audi equivelent of E38 forum
some guy on there straight swapped his G60 brakes for a set of 16v brakes I had lying around because he wanted smaller wheels... He actually downgraded his brakes in favour of looks
You've got the wrong springs for a start, coupe has B3 style suspension, not the updated B4/B5 style.
If it's not lowered already then you'd not do too badly fitting the S2 stock springs, they're lower than a stock car but the same as the sports suspension, 1BE option I think that is on the chassis/service book sticker.
Speak to DarrenM, he's got a V6 or did have, I'm sure he'll shed some experience on the issue.Cheers'en, AndyC
I graduated from the VW skool 6 years ago, keep my eye in every now and again
You want the front and rear springs to look pretty much identical for a coupe.
As for B3/B4, there's a really confusing thread somewhere... the coupe is basically B3 but was facelifted to a B4 to keep the company style. Avant is B4 style with twin wishbone rear, coupe gets macpherson strut...Cheers'en, AndyC
