V6 and S2 subframes
  • gunman
    • Jan 2009
    • 660
    V6 and S2 subframes
    I've doen some searching on here but cnat find a definite answer, is the V6 subframe the same as the ABY? Can it be used on an S2 without any modifications? I need to replace mine, it's fairly rusty .
    1996 Audi S6 Avant.
    1994 80 TDI - Daily Driver
  • spink
    • 4382
    V6 has some reinforcement pieces welded on around the inner seam (so is heavier) but apart from that its the same
    • Kieron20V
      • Mar 2008
      • 1505
      Same as an ABY? Arent the 5 speed and 6 speed subframes different?
      1994 URS4 Avant RS2+
      • gunman
        • Jan 2009
        • 660
        These are the 2 opinions I've found on here, some say they are the same and others say the 5 and 6 speed are different. Has anyone actually fitted a V6 subframe to an S2 ABY? I've found one I could use but dont want to buy, sandblast, paint, fit new bushes etc if it doesnt fit.
        1996 Audi S6 Avant.
        • Skull
          • 3506
          • Country: Slovenia
          the subframes look the same, but the gearbox brackets are different (if you have the 6speed gearbox).
          Audi Quattro WR
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            MY93> V6 subframes are the same.
            SS
              V6 and ABY are the same the 5 speed is different
              • gunman
                • Jan 2009
                • 660
                Were the V6 not 5 speed?
                1996 Audi S6 Avant.
                • BRY
                  • 3755
                  Yes, what he meant to say was that a V6 subframe is the same as the S2 6 speed.
