Loosing Power steering fluid - Help with hoses
  • Jonas_R
    • 3781
    • Country: Denmark
    I'm loosing power steering fluid and it seem to come from my rubber pipes.
    There is a 3-way piece that connects 3 hoses from the steering rack, reservoir and one more place. All hoses seems to be in really bad shape
    Can anybody point me in the right direction where I can find them in the family album?
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • Jonas_R
    • 3781
    • Country: Denmark
    Or part numbers
    • s2driveruk
      • 12696
      i got mine made up from a hose specialist as i seem to remember OEM was really stupid money...
      1992 3b S2 Coupe
      • Audi-Porsche Avant RS2
        • Sep 2008
        • 1041
        • Country: Italy
        Hello, this is a common problem on S2 ABY and RS2, I don't know on 3B because I have not it, if you want change all the pipes I think that is expensive. My RS2 for now have not problems, on the S2 I have cut the original metal connections and put a pair of professional and very good quality clamps made from Wurth on every one pipe and I have not problems from years.
        Bye
        Alessio
        My life and my loves
        Audi S6 C4 ABT Avant
        Audi S2 Coupe ABY
        Audi S2 Avant
        Audi Cabriolet 2.0E
        • URquattroGus
          • Aug 2007
          • 547
          You may find that some pipes "sweat" slightly after many years use, so even fixing leaky joints/fitting may not fix it completely.
          My recommendation would be to remove all of the hoses and then go to a hydraulic hose specialist.
          They will be able to make up a duplicate set of hoses, which should be far cheaper and easier than buying from the dealer. Then you have piece of mind that they have all been replaced.
          Worked a treat with my quattro.
          Angus
          (1984 ur quattro)
          • s2driveruk
            • 12696
            agreed, i had all hoses on my 3b remade by Pirtek for £144 inc vat. One of the HP hoses was £179 + vat from memory!
            1992 3b S2 Coupe
            • Jonas_R
              • 3781
              • Country: Denmark
              Just bought the hoses from audi with my discount etc it was 100 euro. But I only needed the return hose, and hose to the steering rack and hose to the brake bomb. The hoses where leaking where they are joined together.
