Spring length - loaded
  • Rusty
    • 18953
    I'm after approximate lengths of springs, on the car and under load please. It's not too easy but I've measured my blue HnRs and get approximately:-
    160mm Front
    180mm Rear
    Free length:-
    310mm Front
    280mm Rear
    Compression:-
    150mm Front
    100mm Rear
    These translate to about a 635mm rideheight (to the arch) with 225/45R17s, compared to approximately 660mm as stock. This is slightly skewed by different top mounts and removing the rear trim... I'd expect a further 10mm lower on a back to back test.
    We know from previous threads that the spring rate of coupe HnRs is about 200lb/in so
    Front - 150mm compression (6")
    6 x 200 = 1200lb = 545kg
    Rear - 100m compression (4")
    4 x 200 = 800lb = 363kg
    Total = 2 x 545 + 2 x 363 = 1816kg
    A little OTT but then that does not take into account the variable rate and as the front springs are not quite completely bound at the base, this will make a difference.
    Lloyd's thread here suggests that the pre-bound rate is aboutr 130lb/in so using that figure
    6 x 130= 780lb = 354kg
    4 x 130 = 520lb = 236kg
    Total = 2 x 354 + 2 x 236 = 1180kg
    So, assuming a combination of the two spring rates, the stated deflections and rates do seem to be about right.
    I could do with some more measurements from HnR owners and also from people with OE springs.
    I've got some Coupe H&Rs in the garage I can meaasure the free length mate.. will be fitting them soon but won't have the same weight over the front axle as an S2 just yet so i'm not sure any measurements of the compressed length will be any use
    • Rusty
      • 18953
      Yeah, ABY or 3B is more use, can look at Avant too if I can get some idea of dims.
      • Rusty
        • 18953
        Have done some calculations on this to see what sort of sag one can expect on some uprated springs. If I can get a measurement off a stock car then that would be really useful please. Am nearly at the stage where I can start speaking seriously to spring suppliers.
