Power Flex or Super Flex bushes?
  • SE_30
    • Apr 2010
    • 1114
    • Home: England Current: Israel
    I'm just wanting to know the difference between the two manufacturers of the poly bushes Power Flex and Super Flex, are the Super Flex bushes from a harder compound?. I know there is a price difference between the two but thats all
    Stuart
    Stuart
    B2 90 quattro with boost
    If you can use the superflex ones which are of a better design. I frequently have issues with my powerflex ones creeking over speed humps and had powerflex redesign the bushes 3 times but it still didnt solve the issues.
    • SE_30
      • Apr 2010
      • 1114
      See the car is not used very often so would I benefit from going the Super Flex route?
      I mean as little as 3 - 4 times a year it will be driven.
      Stuart
      Stuart
      • Audi Parts Guru
        • 1317
        Superflex bushes are definitely a better quality bush, however Powerflex do appear to have a bigger range of bushes
        • SE_30
          • Apr 2010
          • 1114
          I spoke to a very up to speed woman at superflex who advised me on the bushes and what they had in stock, good job I was sat down when she told me the price of kitting the 90 out with a complete set inc rear diff bush, but as we have all learned we only get what we pay for.. cheers for the info
          Stuart
          Stuart
            Superflex are made in Australia by Superpro as far as I know, they are worth a look too, IIRc they do the whole lot except forged wishbone bushes, which AFAIK only poweflex do in PU.
            Whatever you buy just be careful I had a set of superflex subframe bushes which had big splits in them so make sure you check them over before fitting
            • SE_30
              • Apr 2010
              • 1114
              Well after reading a few of the type 85 project's on here, a few wish they had gone the 5 stud route using S2 struts, wishbones and mix n match CV joints, what do I do now that's thrown a right spanner in the works..
              Stuart
              Stuart
