All Avant wheel bearing replacement
    I'm having to replace all 4 wheel bearings on the Avant in the RS2 hubs front and rear
    Any advice for when they go to hydraulic press shop?
    Notice in the front kit I've got 2 circlips per bearing, can't remember but off hand are these used on the avant / rs2 front?
    don't think you need those circlips.
    make sure they use the right sized drift to press the new ones in against the outer race of the bearing. Will need to be about 80mm diameter
    • madpugger
      • Sep 2007
      • 1901
      No circlips on front or rear.
      They are stepped on the id so ensure they go in the correct way or the hub won't go in!
      They take a he'll of a press to get out!
      Le Mans 2012
      Nurburgring 700
      1995 S2 Avant
      • A80Avant
        • 10873
        • Country: Greece
        yes and you need more than 20T press to get them off. I had all 4 mine replaced a while ago.
          They pressed out my old housing and bearings for the hubs so should be no issues on pressing power
            Do you 100% have to remove ABS sensors? my old rears are going to be a big to remove
            • madpugger
              • Sep 2007
              • 1901
              I wouldn't touch your ABS sensors, just unplug and make sure the lead is out the way when getting pressed. I left mine in in all four hubs. You are just asking for trouble trying to remove working ones!
              Le Mans 2012
              Nurburgring 700
              1995 S2 Avant
                Ah o.k the front ones come out as we swapped them and I then sold the ones I had.
                Acidburn showed me how to disconnect them from under the avant seat, damn weird place if you ask me
                • madpugger
                  • Sep 2007
                  • 1901
                  Yeah it is a weird place, but at least its dry under there
                  Le Mans 2012
                  Nurburgring 700
                  1995 S2 Avant
                    O.K i'll leave them in place, one less hassle sort of
                    Big thanks to Pete Reeve for the price and speedy delivery, between Pete and S2avant at TPS i've had a bat line for parts
                    • mcandmar
                      • Apr 2004
                      • 5118
                      This is on my to do list too, how much were the bearings?
                      91CQ20v - Gone to a new home
                      93UR-S4 - The Magic Carpet
                      94S2Bus - The Emerald Express
                        Avant rears cost same as fronts though
                        • mcandmar
                          • Apr 2004
                          • 5118
                          Thats half of what i was expecting, i have no excuse now..
                            Yeah my passenger side rear hub has a bigger jiggle than Kelly Brook on a trampoline
                            • pixsaudisex2
                              • Sep 2004
                              • 3110
                              Did you not notice the monster of all presses at a that garage that did your engine cleaning think they have three in total..... Depends if i could be free to do them for nothing or they would do it for a wee fee if im not able to meet up with you...
