Started my car up today after fitting ABY steering rack and loads of other bits. Got a problem with the PAS I'm pretty sure I know what the issue is but not 100% how to sort it.
When i fitted it I used RS2 banjos on the rack. Something should have twigged at the time but brain wasn't engaged i guess. The FA called up 2 x non-return banjos for the rack, same part number. The same banjo for the inlet and outlet to the rack.
Now when i start the engine and the rack sees pressure, it forces the rack out to its stop on the passenger side, very forceful cannot then turn the wheel back to the drivers side. Pump also gets hot within seconds so shut engine down. Very difficult to now turn the wheel back towards drivers side and will not go past dead ahead.
Since i used 2x the same non-return banjos on the rack, seems like fluid (pressure) can enter the rack but not get out, hence forcing the rack over and then starting to overheat the pump.
So...... I need to replace one of these rack banjos - I think it needs to be the outlet back to the reservoir? I have a normal banjo to replace it with - just really sanity checking that this all seems logical before i go skinning hte **** out my knuckles changing it!
Cheers for any advice
Alex
Alex
