New Dampers - Where?
  • PiterS2
    • Nov 2009
    • 155
    • Home: Denmark
    Hi.
    I need 4 new dampers for my S2 Coupe. Where can i buy them? I can not really find anything on the Internet?
    Thanks
    Piter
  • quattrostyle
    • Oct 2006
    • 6229
    what do you want? Koni, Bilstein or original (Boge) ?
    • PiterS2
      • Nov 2009
      • 155
      • Home: Denmark
      I have heard good about Bilstein, but other good brands are welcome
      • Jonas_R
        • 3781
        • Country: Denmark
        You could buy a H&R Cup Kit comes with springs and dampers and lowers the car 50/50
        If you want original I would buy the from Audi Zentrum Flensborg and use your Audi Club Denmark discount.
        Sleeper S2 Avant +450
        A6 Avant 2.7t Stage 3
        Audi S2 Coupe RS2'ed
        • PiterS2
          • Nov 2009
          • 155
          • Home: Denmark
          Jonas i think H&R are to expensive. Do you know how much they cost at Audi?
          Or a link to some bilstein dampers.
          • driftin jo
            • Sep 2007
            • 2222
            FRONT PART NUMBER PE3-3086
            REAR PART NUMBER P36-3058
            • Tonks4x4
              • Nov 2005
              • 3062
              eBay....
              Fronts Link
              Rears Link
              I used P36-3017 for the rears of my coupe as in the link above
              Got these on mine....
              Audi Nut!!!
              • Jonas_R
                • 3781
                • Country: Denmark
                They are 800 euro on ebay that is 6000 dkr. Not that expensive for a complete suspension me thinks The bilstein dampers will end up in 600 euro then is it only 200 euro for the springs.
                The H&R Cup Kit comes in two version depending on wether your strut is M50 or M55. The kit contains bilstein dampers and H&R springs.
                29939-1 Audi S2 Coup� Quattro type 89 Q, with front axle M50 x 1, 5
                front axle30, rear axle30, 29939VA1, 29939HA1, front axle M50 x 1, 5, year: from 09/90 | Notes: 22 32
                29939-2 Audi S2 Coup� Quattro type 89 Q, with front axle M55 x 1, 5
                front axle30, rear axle30, 29939VA1, 29939HA1, front axle M55 x 1, 5, year: from 09/90 | Notes: 22
                Ebay link for H&R Cup Kit 29939-2
                Ebay link for H&R Cup Kit 29939-1
                • Rikki Kitto
                  • Feb 2010
                  • 6276
                  There are some Bilstien B6 rears on ebay £210 the pair
                  • PiterS2
                    • Nov 2009
                    • 155
                    • Home: Denmark
                    Thanks for all your inputs
                    • PiterS2
                      • Nov 2009
                      • 155
                      • Home: Denmark
                      I have one more question. Can i use my standard springs or do i have to buy fire new lower springs? How does it work with bilstein PE3-3086 and 3058, because it's different dampers.?
                      Thanks
                      /Piter
                      • PiterS2
                        • Nov 2009
                        • 155
                        • Home: Denmark
                        Bump.
                        • Rikki Kitto
                          • Feb 2010
                          • 6276
                          Got mine from Balance Motorsport, Google it, Europarts sometimes come up OK too
                          • PiterS2
                            • Nov 2009
                            • 155
                            • Home: Denmark
                            Ohh i know where i can buy them but my question is I have doubts about my car will run properly with two different dampers and my standard springs. Will my car not look weird, because the sprint damper are lower than the sports??
                            • vertigone
                              • Nov 2009
                              • 253
                              • Country: France
                              Hello,
                              H&R cup kit comes with B8 dampers + H&R springs
                              So if you want to keep OEM springs, do not take B8(short), B6 would be fine and will keep a good ride height
                              91' S2 3B Pearl White
