As a cheap 'workaround' you could get some of those poly spring inserts.
They will rapidly increase your effective spring rate when coil bound (compress less) - a bit like hitting the bump stops early.
I've considered trying out a set on track as the RS2 H&R are in reality still soft for aggressive cornering. Will let you know how I get on, I've a day at Spa and the 'Ring coming up in July. TBC
