S6 bushing renovation/upgrades
  • goodall
    • Jul 2008
    • 810
    MOT is up on the S6 and feel need overhaul the suspension for her to pass
    So far have replaced the front arms today, also have stock top mount to put in as well. However looking do the rear end and the subframes. Can't find anything for doing the the rear with, other than replacing top link with stock replacements, would really want do lower arms with poly along with the front ARB to subframe bushes. As for the subframe bushes, only can find poly ones from apikol and don't want go as harsh as aluminium, shes got a auto box.
    As for dampers which are worth the money or would standard spec be good enough for another 10-15 years
    Has anyone used bambridges nylon bush for rear tie rod on typ85/89 on the front tie rods?
    UrS4/S6 Suspension Info
    Don't know if these will help you or not but...
    UrS4/6 front suspension info:
    UrS4/6 rear suspension info
    watch for the hint about the rear CV joint in this one:
    http://forums.audiworld.com/showthre...ear+suspension
    • bambridge
      • May 2009
      • 609
      Hi, i have also made some delrin rear sub-frame bushes for the urs4/6 which a few members have fitted
      • goodall
        • Jul 2008
        • 810
        Hi thanks links, haven't got etka at moment so good see what all need to get before taking too much a look at the car
        Originally posted by bambridge
        Price is £45-00 a set delivered in UK.
        They still £45 bam? If I can get all the other bushes in oem spec rubber for the rear this would be about the right amount off increase in stiffness I'm looking
        • bambridge
          • May 2009
          • 609
          Yes Mate, still £45-00 delivered
          Kev
          • goodall
            • Jul 2008
            • 810
            May give you a shout before end weekend
            After a bit of a serch I've found out that one of the bushes on a typ44Q style rear end is same as that use B4 quattro rear end, part number 4D0511523C. This can be got in poly, after trying cross referance the other bushes to the B4 chassis there are other bushes which share the middle and end of their part number, dont know this is due to audi part numbering nomicultrul makeing bushes in same relitive place have same numbers after chassis designation. However may investigate furher...
