Rear Sub Frame Refresh
  • Dpicariello
    • Mar 2006
    • 621
    Evening everyone,
    My S2 went for it's 5th MOT of my ownership the other week and again has passed with flying colours. I'm fortunate that the only thing that has ever caused an issue in the MOT has been a headlamp that wasn't properly aligned!
    However, Jason at Lion garage said that my rear sub frame could do with keeping an eye on. I've had a good look under there and although it's not bad at all, I haven't really ever touched the rear suspension and so I've decided to pull the whole lot out.
    I've read lots of guides and seen a few lists but just thought I'd check as I know a lot of people have done this and will no doubt be able to offer advice.
    Plan is to drop the subframe and send it along with my rear wishbones and anti roll bar to be blasted and zinc primered. I haven't decided whether to get them powder coated or go the POR15 route that everyone raves about it. Cost and time is going to have an influence though.
    If anyone can recommend somewhere central (I live in Warwick but am open to travel within the midlands) that can do this then please let me know.
    I'm going to replace the sub frame bushes with superflex polyurethane mounts (not sure if I want solid mounts).
    I'm going to replace the diff mount with a powerflex one
    Wishbone bushes will be replaced of course (probably with powerflex ones but may stick with OEM as the front is all OEM).
    Anti roll bar bushes are absolutely fine, I had that off the other day and they are like new.
    Drop links look fine too so may keep them but I'll have a good inspect of them when they are off the car.
    Top mounts will be done. I've seen that Pete Reeve has some heavy duty ones available now so may be in contact with him.
    As always any advice, top tips will be much appreciated. Also, if anyone has any of the parts above for sale then please let me know.
    I'd really like all parts before I start and so I am properly planning this and intending it to do during the bank holiday bonanza at the end of next month.
    Dan
  • s2driveruk
    • 12696
    you won't be alone Dan, I need to get my rear subframe blasted.
    Pretty easy to drop it as one complete unit, just need to crack off and separate the prop from the diff and likewise with the inner driveshafts off the diff cups.
    I have found it easier in the past to get the subframe bushes pushed out at a local garage - cost me less than £20 and easier than messing about cutting or burning IMO.
    I wouldn't worry about the rear topmounts as they take very little abuse compared to the fronts. My blues which had been there 4-5years when i replaced them looked almost new and non-compressed, i could honestly have saved the time and money. If they haven't been replaced before then could still make sense and those HD ones would be fine I'm sure.
    david
    1992 3b S2 Coupe
    • Fat Audi 80
      • 10547
      I think you have already chosen the right spec Dan. I have exactly what you describe on my car, which I did in 2009. Don't be under any illusions though, if you are doing this on your back in a single garage is it a ****ing 'mare of a job. It took me two weeks of evenings and weekends.
      I stripped my rear subframe out completely as I didn't want to muck about taking the diff off. The main problem I had was getting everying undone, particularly the rear diff mount both that had completely rusted up and had to be cut out by hand.
      David makes a good point about the old subframe bushes, they are pain to get out without a press and I made a real mess with heat and drill bits etc. Much better to pay a local garage to press them out in 10 mins.
      However the results are worth it, I have the spec you describe (including powerflex wishbone bushes)and don't feel as though it is any harsher at all, but does feel solid and more planted at the back. I am just trying to summon up the courage
      to do the same at the front.
      Also, don't forget to double check which way round the Supaflex subrame bushes sit, there is a chamfered side to one half that is designed to allow access to wishbone bolts, if you get them the wrong way round it is hard to do those bolts up...
      Best of luck.
      Cheers,
      Steve
      The Perfectionist
      • willg54
        • Jun 2009
        • 2055
        Im in the middle of doing it now.
        I took the subframe and wishbones to Redditch Sandblasters and Powder coaters. Used them before and very reputable for vintage restoration work. Going to get Carl or Lee to seam weld my wishbones too Im only getting them sand blasted and painting the subframe and wishbones in POR15, the rest is getting powder coated.
        There is a alternative to the wishbone bushes similar to the top mounts, Pete at QC supplies them. Same principle, kind of a mid-way house between oem and superflex.
        Id second the wishbone bush removal comment, complete PITA to get out...Or if you're going oem bushes, just buy a new wishbone. doesnt cost much more IIRC and comes with bushes pre-installed!
        • Dpicariello
          • Mar 2006
          • 621
          @Steve: I re-read your thread on your sub frame removal and remembered how tough it was and also how the anger was well described!
          Yes, i'll be on my back in a single garage and have prepared myself for a tough slog. I have taken the days off between the royal wedding and Easter so should have over a week where I can concentrate on getting stuff done.
          @Will: I'd forgotten about Redditch Shotblasters. Only heard good things about them so reckon they could well be worth using.
          I'll take the advice of getting a garage to remove the bushes.
          @David: You could be right with the top mounts. It may be more hassle than it's worth as there's no clunking from there. My only reason is that I've never touched the back end of my car in the time I have owned it (not needed to) whereas the front has been completely rebuilt.
          Dan
          • willg54
            • Jun 2009
            • 2055
            I've had work there before and you can't fault it. The quality of the work is amazing. He has all of my stuff at the moment and a second batch on the way when the front subframe is out. If you call and mention s2 he'll know and will be more than willing to help! Top bloke! Fairly quick turn around, for my 24 items, wanted 10 days!
            One thing is recommend, get some wd40 or similar into the chassis member for the subframe mounts. There is a small hole up there. You don't want the nut breaking inside the chassis. I had a head break off one stud...still yet to extract it...
            • willg54
              • Jun 2009
              • 2055
              Dan,
              If you want some superflex rear subframe bushes, I have a set!
              Will
                another vote for Redditch Shot Blasting, I used them loads when i lived in Kings Heath, top work
                IMHO dropping the rear subframe is not a bad job at all if you have a decent trolley jack and some axles stands to get the car a decent height off the deck.
                I would recommend changing the topmounts while you're in there, as its a 5 minutes job per side with the subframe off and for the sake of £20.......
                There will never be a better time to replace the fuel and brake hardlines too
                  I know of them but I used to use Bournes in Brum city centre.
                  Having done both on a Coupe and Avant I wish you luck and patience and fair bit of wiggling
                  • Fat Audi 80
                    • 10547
                    You obviously havent tried this in an 9ft wide single garage where you can't even get a jack under each side of the car. It takes me between an hour and two hours just to get the car up in the air on axle stands. Don't start me off about the contorsionism required to get underneath the car. Then you realise you have got under there with the wrong tool and have to reverse your body back out. Almost the worst two weeks of my life.
                    I have just started doing the same on the front.
                    The Perfectionist
                      ok fair enough Steve, I've never done it Tetris style!
                      • Dpicariello
                        • Mar 2006
                        • 621
                        I had a trial run at it this week in that I started trying to break bolts loose (one by one on the sub frame as I didn't want to **** up my alignment).
                        All 4 subframe bolts came undone fine and my anti roll bar clamps also came away fine (seen a few horror storied of these shearing off). Side diff mounts also came away OK but I may as well leave them until the subframe is off.
                        The only bolts I didn't try were to free the diff as I needed the car today and so had to get everything back together.
                        I'm ordering stuff from Pete @ Quattro Corner tomorrow. Gonna go for standard wishbone bushes and diff bushes but think I'm going to try solid aluminium sub frame mounts from Bambridge as that seems to be a nice combination after reading a huge amount of feedback on here.
                        Any tips for getting the diff free?
                        I will make sure I get the car as high as possible when I come to do it. I hate jacking the S2 up, it's so bloody heavy and I hate using the sills. I've never put axle stands on the sills, guess I'm gonna have to this time though.
                        • Fat Audi 80
                          • 10547
                          Sounds like you are taking your time and have most of the details worked out. I did not take the diff off so can't offer any advise there. Don't forget you will need a 3 leg puller to remove the ball joints from the control arms (unless you take the control arms off the sub frame, but mine wouldn't budge)!
                          I seem to remember putting my axle stands on the reinforced "inner" sill for want of a better word. I certainly wont go outside the welded seam next to the sill.
                          Good luck when you finally commit yourself. There is no going back once the car is up in the air on axle stands and nearly all the subframe bolts are out!
                          Cheers,
                          Steve
                          The Perfectionist
                          • s2driveruk
                            • 12696
                            Dan, are you leaving the Diff and prop attached and dropping the subframe, wishbones and arb?
                            If you are leaving it on the car so to speak, then you need to crack off the rear diff mount bolt which depending how it looks might be easy or a nightmare as they get well cruded up...I'd soak it in some penetrating fluid or plusgas etc?
                            Failing that you'll need to disconnect the vac lines x2 and then remove the inner driveshaft bolts and the 6 cap head bolts on the rear cv of the prop...which will mean you need to tie up the prop or risk messing up the universal joint. of course then your well into 'i could replace the centre bearing on the prop......can of worms
                            1992 3b S2 Coupe
                            • andy10v
                              • 5996
                              If you are taking off the diff then make sure to decide how you are locking the prop/driveshafts to undo the bolts before you remove to many parts.
                              Sold ABY-stock
