Rear Sub Frame Refresh
  • marshall
    • Jan 2008
    • 47
    Doth of the cap sir! Glad you finally got it aligned mate
    • willg54
      • Jun 2009
      • 2055
      Dan, just looking at the pics of your subframe assembly...the 2 side diff mounts in the pics on page 3 are the opposite way round to the ones on page 4
      im trying to figure it out for myself...took mine out back in january!!
      • Dpicariello
        • Mar 2006
        • 621
        The passenger side mount is upside down in the picture when I got everything back from the shot blasters but the mounts are on the correct side of the diff. The one with the angled face clears the exhaust pipe.
        However if you are talking about the actual rubber mounts (just re-read your post) then they should be fitted from the 'underside' of the subframe (they are just placed loosely on my 'new' picture). Make sure you get the aluminium cups the right way round as you can crush the mount.
        • willg54
          • Jun 2009
          • 2055
          Yea, i meant the rubber mounts sorry. I remember them being fitted from the underside, its just the orientation i cant quite remember. Do they both sit the same way although one mounts from on top and the other from underneath? (hard to explain...) Which was is right for the aluminium cups?
          • willg54
            • Jun 2009
            • 2055
            http://www.s2-audi.co.uk/tech_articl...r_subframe.htm that answers some questions lol
            • Tom_
              • Oct 2007
              • 1301
              • Country: Czech Republic
              #66
              mine rusty subframe.I am thinking,if the sandblasting take off the rust.
              Audi Coupe Quattro 2.3 20V
              • quattrostyle
                • Oct 2006
                • 6229
                interesting way to secure the exhaust..
                • Rusty
                  • 18953
                  Yowsers! That's got some rust on it! I'd say that you need to inspect it thoroughly to make sure that it's not rusted through where the rear tie rods attach. Mine wasn't that bad and has rusted through in that area
                  Also, where's your rear anti roll bar
                  • Tom_
                    • Oct 2007
                    • 1301
                    #69
                    it looks bad,when i take off,i inspected,if its ok. I dont know,where it is.I am not getting down . I am prayin to,that subframe was ok after sandblasting.If its not,it will be problem to find some good one
                    • Colesy
                      • Feb 2009
                      • 2980
                      Just finished painting my rear subframe with POR-15 today. It was quite rusty, most was surface rust apart from around one tie rod mount where it had rusted through almost exactly as Rusty's had done (in another thread). After shot blasting took it to a local welder who made up a plate and welded it in for ÂŁ40 and it looks perfect now. Will be fitting it back onto the car tomorrow when the paint has dried.
                      In all I've replaced all subframe mounts, diff mounts, wishbone bushes, ball joints and some bolts + have refurbished the tie rods and subframe, has been an ok job to do so far, hopefully everything will go well putting it all back together.
                      I ordered POR-15 from www.holden.co.uk who have smaller tins of it in stock. To paint 2 coats onto the subframe, tie-rods & front struts I've used just over half a pint.
                      Mike's guide has been a great help as have all the posts on here.
                      • martinws
                        • Oct 2008
                        • 917
                        Really, thats hardly anything. Iv not had much experience with PO15 but i have a tin in the garage that will be getting used very soon.
                        And at rusty. Is this maybe a Typ85 subframe with no ARB? or it might have rusted away!
                        • quattrostyle
                          • Oct 2006
                          • 6229
                          AFAIK only S2's came with the rear ARB, and the signature shows CQ 20V...
                          • martinws
                            • Oct 2008
                            • 917
                            I actually noticed the sig after i wrote the comment but then could not be bothered editing it.
                              IME the early quattro subframes are made of far better quality steel than the later ones, I'm yet to see an early 20v subframe rusted through so I think it will clean up nicely after a blast. The tin worms loves ABY ones.
                              • SE_30
                                • Apr 2010
                                • 1114
                                • Home: England Current: Israel
                                #75
                                Originally posted by martinws
                                Really, thats hardly anything. Iv not had much experience with PO15 but i have a tin in the garage that will be getting used very soon!
                                I've used POR15 a few times now, make sure you use a pair of gloves Martin, if you get it on your skin it's a f**kin nightmare to get off, Lesson Learned for me
                                Stuart
                                B2 90 quattro with boost
