Just remember this thread, was wondering it a paddling pool might be suitable for subframe, might be difficult not to puncture it though. May give this a try with a few smaller components soon too.
Electrolysis subframe rust removal
Great thread, Im giving this a go with my subrame as we speak. cant completly cover it all but doing it in sections and must say that it does appear to work quite well!! been reading about the process to and it seems that it is a non-destructive method, which is good.. glad i read this now. good brain food1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
Just checked subframe and heavy rust and grime/oil just washed of with a hose!! it also gets the inner part of the frame which is a bonus, and like originaly posted never draws more than two amps on a fairly heavy duty charger. well impressed, going to do what i can this way as its cost me nothing so far!! except the baking soda im gonna have to replace later.. top job for the diy'ers1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
I have just cheated and sent mine for blasting and galvanising
Was worried that it would come back on the shape of a crisp, but it's has come back fine and all measures correctly
Yes Vas it's galvanised
And John I don't really know as I bundled it in with a load of other stuff I was sending. When the rest comes back tomorrow I will try and work it out as its all calculated by weight.
Originally posted by bartolomeus View PostQuick question, would this be a good thing to do after removing rust?
1) POR-15 Prep and Ready (previously called Metal Ready)
2) POR 15 Rust Prevention Paint
3) POR15 Chassis Coat Black Paint Topcoat
Or only POR 15 rust prevention paint would be enough?
Originally posted by bartolomeus View PostAnybody? I could really use some help...
If you just use POR15 it can peel in places.
And If you dont paint over it after it fades to a dull grey if sunlight ever gets to it...
looks good Brian. I am getting my front and rear subframes as well as my wishbones all galved in the next few weeks. They quoted me roughly a pound per kilo as long as the stuff is quite small(small being not 10x10ft gates or anything) Im going to POR15 over the galv afterwards for extra protection and for the look. I guess the bare galv is more than up to the job anyway even when chipped the cathodic protection will keep it good.
My slight worry is that my bambridge ali subframe mounts might be a bit tight afterwards.
I'm guessing you'll probably have to file/reem out the subframe bushing holes after galvanising. Should last pretty much forever though!!!Black B3 1990 CQ 2.3E converted to ABY & 6spd. (301bhp) - Now Sold
"Difficult is worth doing"
