power steering pump jetting fluid out
  • s2driveruk
    • 12696
    through the big crosshead screw and soaking the front of the engine god i hate that green goo.
    Am i right in thinking there are two large screws as while the pump is coming out I will do them both and change the o-rings on the hoses too
    1992 3b S2 Coupe
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    yes there are.
    they are supposed to be there to allow for the dual vane pump to work as a ... 'dual' pump.(for the brakes and all).
    • jade
      • Jan 2005
      • 1811
      For this repair Buy new o rings and caps, OEM, screws what ever they are called
      If you just change the o ring they will fail again in a short time
      RS 2 580HP
      • s2driveruk
        • 12696
        anyone confirm the part numbers on a 3b pump for the rubber orings and copper washers on the 3 banjos to and from the pupm as i might as well change these too.
        Thanks,
        David
        1992 3b S2 Coupe
          I had my "reconditioned" PS pump on and off the car about 6 times before I got all the leaks. I seems what the rebuilders do is to dip the units in acid to clean them without first removing the plugs and O-rings. The acid gets washed off but some remains in the nooks and crannies.. So the acid sits there eating away the rubber and within a week or two you have another leak. There are 2 small brass plugs with O-rings as well as the 2 big cross-head ones. You need to replace them too. Also clean the gauzes in the banjo bolts, these can block up with debris (rubber debris from rotting O-rings?) and cause the seals to fail early as the pump is overworking..
            there is another cause of this which someone was speaking about at the MRC meet where a gauze in the pas pipe gets blocked or turned around causing pressure build up
            • s2driveruk
              • 12696
              useful feedback Newsh - cheers, I'll add those to the listing too. The fluid was coming out the usual spot but worth giving it the once over to hopefully avoid having to revisit it again within a few weeks. Jamo - I think the one you're talking about is the reducer in the p/s line which can get dislodged and either cause a spike in pressure or just get noisy like mine is having been rebuilt bu Pirtek in the past. I *might* just get that line remade again in an attempt to silence it
              1992 3b S2 Coupe
