Fitting alloy subframe mounts to a coupe
  • 91_S2
    • 612
    Tom,
    Love all your ideas. Where did you get those alloy bushes? Made 'em? Those pics of the tool you promised would be nice.
    Rich
    • audiman
      • 4827
      Christ forgot all about that sorry, I will take some photos of it asap.
      Tom C - www.rcmr.co.uk
      Audi UR Quattro
      Audi 100 C3 2.0 5 cyl 115ps
      Audi B5 RS4 645ps 911nm
      • 91_S2
        • 612
        Thanks Tom.
        I am doing just about everything I can think of to get the pig to handle.
        I sure would like to find a way to get more caster. Anyone with bright ideas?
        Rich
        • audiman
          • 4827
          Do Bonrath do anything??
          Audi UR Quattro
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            #20
            For more caster, you could jack up the rear & lower the front of the car. :mischeif:
            SS
            • Stick Insect
              • Dec 2003
              • 2338
              • GeorgeS2UK
                • Oct 2004
                • 225
                • Home: England
                #22
                Originally posted by audiman
                Can do, but i will have to clean it up first
                It got a bit dirty when using it its too hard to describe, but would be dead easy to make a copy for removing the bushes etc.
                Tom
                Do you still have tool 3301 or pictures of this much needed tool
                Borrow, Buy or Rent
                Regards
                George
                91 S2 3B in Pearl, Miltek, De-Cat pipes, Short Shifter, 996 Monoblocks + 323 A8 Discs, Whiteline R-ARB:MRC Generic 3B Chips
                • audiman
                  • 4827
                  I still have it, its not mine tho, but contact S2avant if you want to borrow it.
                  Audi UR Quattro
                  • A1QSHIP
                    • Aug 2004
                    • 975
                    subframe bushings
                    Look at these. http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW. NCTS!
                    Give you any ideas? Moving the front subframe foward will give you more caster.
                    I tried getting more caster by swapping the lower front ball joints from right to left.
                    I got about 6 degrees of caster but ran into interference problems with the tires & inner wheelhouse liners at full lock. This was with the stock Coupe wheels with 205/60/15 tires. Using these bushings would not give as much caster gain but may not cause interference issues.
                    Chris
                    "Nulla tenaci invia est via"
                    • RSCoupe
                      • Dec 2003
                      • 120
                      Originally posted by TECH48
                      They are mine now, all mine.
                      To bad it will be a while until I know how well they work.
                      Mark Siggelkow
                      '90 CQ 20vT - NASA GTS-5 (R.I.P.)
                      '90 CQ-R - NASA GTS-4/5
                      '00 A4 1.8TQMS (Wife's Daily Driver)
                      '12 TT-RS (Wife's new DD, on order for May European delivery)
                      '62 Porsche 356B (another race car)
                      '03 Kawasaki Z1000 (toy)
                      • A1QSHIP
                        • Aug 2004
                        • 975
                        Bushings
                        @ RS Coupe. You have a PM.
                        • kwlw
                          • Sep 2004
                          • 1025
                          • Country: Lithuania
                          #27
                          It would be nice if you post impressions, photos and dimensions here. Someone want's to make local copy if they work. Also as far I see, there is need to weld subrframe a bit, jus to make fixation points for these alloy mounts.
                          Sau
