anybody had a subframe galvanised?
  • terrybullwon
    • Mar 2006
    • 8782
    Shane all mine were Zinc plated and baked
    Chef
    • s2_wot
      • Aug 2006
      • 2178
      Originally posted by DS2
      I had everything from under my car galvanized and no problems but you have to let them 'dry' for a week coz its pretty soft at first when they do it
      Any link to the company that did the work so I could compare processes?
      Originally posted by terrybullwon
      Could always get them Zinc plated or Zinc Barrel plated?
      Same question James, is this the electroysis process? Am I right in thinking that the steel not heated and cooled in this process?
      Shane
      • terrybullwon
        • Mar 2006
        • 8782
        Don't really know, they were baked after zinc coating as I saw them bare
        Chef
        • AndyP
          • 6049
          They do get heated but not to a point where the properties of the steel will be altered, or warping could occour. You will not get the inside plated by zinc plating them either as it works on line of sight.
          • s2_wot
            • Aug 2006
            • 2178
            #20
            Very good, I'll have to ask a few more questions of the potential suppliers over here and see what they can offer.
            Thanks to all for your input.
            Shane
              Good point about the line of sight on plating Andy.
              We had 6m girders warped like bananas when they come back from galv.
              Could get them acid dipped and e-coated, then powdercoat / 2k / POR15 paint.. would be very expensive though.
              I sprayed mine inside with cavity wax, should help
              • s2_wot
                • Aug 2006
                • 2178
                #22
                Ok what I've learned today I think is that zinc plating will be better than galvanising.
                No heat just electricity is used.
                I'm going to contact the company linked above and see what they think when I show them a freshly blasted subframe. If they can get the inside done we could be on to a winner.
                Shane
                • irishs2
                  • Apr 2009
                  • 2455
                  Very interesting, I do have great faith in POR15, but zinc plating has obvious benefits.
                  If you are going the powder coating http://www.barelleltd.ie are very impressive. I got a sample front subframe done by them a few months back as a trial run for the avant running gear. I will post pics of the subframe tomorrow.
                  Eric
                  95 S2 Avant under rebuild.
                    The zinc is sacrificial, ie. the steel shouldn't rust till the zinc is gone. So having some zinc on the car will help to keep all the steel (which is electrically connected to it) to remain in good condition.
                    They use aluminium too. Mmm, maybe those big Procon ten brackets have been looking after my car
                    • campbellWS
                      • Oct 2010
                      • 446
                      anyone used this, i got a galon of this for free it sounds pretty good. my local fabricator uses this to patch pree dipped galvinized items that he has modified, quite expensive? 1.9 litre = £58.79 16msquare per litre. I have used it before and it is definately worth it, I think por15 is harder wearing tho
                      Buy high-quality paints, coatings, and painting accessories at Tools-Paint.com. Shop trade and DIY supplies, including custom paint mixing, with fast UK delivery and expert customer support
                      • s2_wot
                        • Aug 2006
                        • 2178
                        #26
                        http://www.tools-paint.com/product/G...n_Galvfrd400Ml
                        I've just painted my ARB with it as a test. I also used it as undercoat for my struts. It's a rediculous heavy weight compared to a similar quantity of normal paint.
                        I spoke to the company I listed in my last post. They have no plating facility in Dublin but the people in Shannon do have the facilities and can plate the inner parts of the subframe. Price not discussed until they see the part.
                        Nickel plate + powdercoat I think he said.
                        Shane
                        • irishs2
                          • Apr 2009
                          • 2455
                          Any update on this Shane?
                          Eric
                          • s2_wot
                            • Aug 2006
                            • 2178
                            #28
                            I'm going to meet them tomorrow and make a decision about what to do. I think I'd prefer to plate it and paint it myself afterwards. I just know I'll be annoyed with a powdercoat after a few thousand miles.
                            The sub frames have been are shot blasted (inside & out) and are in the back of my car.
                            Shane
                            • Tzummie
                              • Mar 2011
                              • 116
                              check this out:
                              (ignore the acid stripping)
                              I've done a lot with electrophoretic coating: Electricity-based, no heat. Ideal in combo with powder coating, highest score on salt spray tests. It's the same treatment as manufacturers use for their parts/panels.
                              Just a suggestion...
                              T.
                              • s2_wot
                                • Aug 2006
                                • 2178
                                #30
                                Ok so I got the subframes shot blasted. €40 each.
                                Then dropped them to the metal finishing company in Shannon. The guy there said that they couldn't be galvanised and that zinc plating on it's own wouldn't be enough.
                                We settled on zinc plating + e coat. This should give total coverage inside and out of the subframes and shouldn't chip the same as powdercoat.
                                I'm collecting on Monday / Tuesday. Oh yes I should mention cost. We agreed the cost would be somewhere between €40 and €50 each. I can't argue with that if the finish and longevity is good.
                                Also the e coat can be painted over with loads of other paints so I'll have the option to paint it yellow or something afterwards.
                                Shane
