Folks,
Question/advice: after stripping out the rear end of my coupe (sub frame, struts, drive shafts, diff) I'm wondering whether it's best to put it back together in separate bits (reverse order of dismantling) or if I should assemble the rear subframe together with the diff and wishbones on the bench and then lift the whole thing on?
Will I be able to get to all the diff connections I need and to the drive shafts or will the sub frame get in the way?
Ta in advance.
Derek.
Ta in advance.
Derek.
