Loss of power steering fluid
  • Rikki Kitto
    • Feb 2010
    • 6276
    AAAArrrggghhh, what next? starting to lose fluid now from power steering tank, cleaned it all up to see what's happening no obvious leakage. Think maybe seeping from the rams! is that the right word for them? any usual suspects for this sort of loss when not obvious?
    PS just had a new pump fitted as that used to weep but now is bone dry so not that
    have a good poke about underneath with a torch, its horrible sticky **** you'll be able to see where its leaking from.
    • s2driveruk
      • 12696
      plenty of lines and joints that can leak - its horrid stuff and shouldnt take long to spot
      1992 3b S2 Coupe
      • Rikki Kitto
        • Feb 2010
        • 6276
        Had it up on the mechanics lift sprayed cleaner everywhere, including my eyes, cleaned it all off watched for a while. Nothing jumped out at me but like you say loads of possibilities, should be great fun trying to find it.
          if its not the pump, then its either the rack, bomb, reservoir, servo or the fluid lines themselves. Follow the circuit until you find a sticky wet patch
          • Ross
            • Aug 2005
            • 3399
            I can agree it's nasty stuff - had the bottom of the front sub frame constantly covered in the stuff. It turned out that a jubillee clip on the bottom of the reservoir needed an extra couple of turns and it's been dry ever since...
            • ADU_S2
              • May 2004
              • 164
              i had the same issue the power steering pump seal was leaking. at the end went through 4 refurbished powere steering pumps and all were leaking from the seal which you can see from the top of the engine.
              replaced it with a used one at the end.
              • Rikki Kitto
                • Feb 2010
                • 6276
                MMmmm sticky wet patch is basically the whole bottom of the car, try to clean it of best I can, might get it steamed, is this a good or bad idea?
                • Rikki Kitto
                  • Feb 2010
                  • 6276
                  Oh no, think it may be the steering rack how much of a job is this? anyone got any ideas on time and complications
                    Steering rack is not easy .. slightly easier on an ABY without the battery tray in the way.
                    • Rikki Kitto
                      • Feb 2010
                      • 6276
                      What needs removing to get at it?
                        Brake MC and servo, ISV, inlet manifold, downpipe probably - never done it on an S2 mind you.
                        On a 3B with the battery tray I'd rather pull the engine....
                        where is it leaking from on the rack? sure its not the hoses?
                        • Rikki Kitto
                          • Feb 2010
                          • 6276
                          Still checking things out but it does look as though it's the rack
                          • Rikki Kitto
                            • Feb 2010
                            • 6276
                            Turned out to be a 50p jubilee clip that I missed first time round, That felt horribleCheers for all the help chaps
