power steering pump - differences 3B ABY?
  • LHD_Kid
    • May 2006
    • 3695
    Been searching the forum for a while, but cannot find a definitive answer...
    What would be the issue with fitting an ABY PS pump to a 3B?
    The car already has an ABY rack fitted...
    What could go wrong?
    Chris
    Originally posted by LHD_Kid
    Been searching the forum for a while, but cannot find a definitive answer...What would be the issue with fitting an ABY PS pump to a 3B? Chris
    I asked my friendly parts person and she says that the 3B and ABY both use the same tandem vane PS pump, i.e. 034145165 X up to L006900 and then 054145165GX from L006901 to L030000. After that, i.e after M00001, it was 8G0145165 X. The real difference is the 3B and ABY use different v-belt pulleys, i.e. 3B = 035145255E (also 7A and NM) whereas the ABY pulley is 034145255.
    Here is some PS pump info (intended for AAN owners but might be useful anyway):
    • djh
      • Jun 2011
      • 1622
      • Home: United States Current: United Kingdom
      Should be able to swap the pulley by undoing the 3x allen key bolts
      • irishs2
        • Apr 2009
        • 2455
        My memory might be off, but I think you might need heat too to take the pully off.
        Eric
        95 S2 Avant under rebuild.
          Depends if it's been off before if it has it will pull and wiggle off
            easy, use a puller, its an interferance fit
            • irishs2
              • Apr 2009
              • 2455
              Ah my bad.
              Eric
              • LHD_Kid
                • May 2006
                • 3695
                Thanks Fellas.....!
                • Dobby84
                  • Feb 2011
                  • 1169
                  Are there any physical differences between the two, is the pump body the same and just the pulley thats different?
                  • veneto rs2
                    • Jun 2006
                    • 1022
                    • Country: Veneto
                    ADU/ABY/AAN/3B and even 1.8 four cylinders of the late Audi Cabriolet have the same pump.
                    Pulleys could be different
                    http://www.audisportclub.com/
                    • Dobby84
                      • Feb 2011
                      • 1169
                      Cheers for that
                      • Farhazaftab786g
                        • Nov 2017
                        • 169
                        Does the 80 2.6 have the same pump as the S2 ABY as i need a pump on my ABY and someone is selling one off a 2.6 the part number from that pump is GO145165
                        Emerald Green ABY Coupé
                        RS2+ Spec
                        @audis2kid - instagram
                        • varia
                          • 821
                          • Current: United States
                          I believe that pump is a single vain pump.
                          • Farhazaftab786g
                            • Nov 2017
                            • 169
                            Part numbers seem to match up also the pump looks identical to the one on my car.
                            RS2+ Spec
