There are 2 lines on the side of the tank, not on the thing you remove, this is just a float switch assembly not a dip stick.
You look at it from the outside to see the level.
You may have to wipe it clean before you can see where it is at.
thanks for the advice, I'll check the Tee piece tomorrow if time allows. A daft question, whats the correct level for the power steering fluid ? Removed the top and it has spring piece attached but couldn't see a level mark ?
There's a white tubular insert in there with 3 cutouts (like a castle turret?) fill to the bottom of the cutouts. Trouble with the hydraulic oil is it get everywhere, its a good idea to wash it all down and allow to dry, start the engine and see where it appears first. It could well be leaking at the jubilee clip on the bottom of the reservoir and blowing back.
