I thought I should put a quick post up as I couldn't find much info on these... I wasn't quite convinced enough to go for the Powerflex front wishbone bushes on the RS2. Comfort really is priority over looks (why else would I be on stock springs
So - I heard Quattro Corner supply a set of high-density rubber bushes as a comprimise and decided to take a punt on them.I haven't had the car aligned yet but took it for a quick blast after picking it up last night for some first impressions.
There is maybe a tiny bit of vibration, but the fact I couldn't decide means it's very minor if so. Improvement in handling was very impressive. Initially it felt a little more responsive, definitely more planted and 'sure' of itself nipping out of town - once I got it on a few twisties, the advantage was more pronounced... I took it down a few twisty, wet and bumpy lanes that would have had me nursing understeer previously and I could really attack them. I could give it WOT in 2nd and 3rd, through corners, with real confidence that it would turn in and respond. Actually it felt very neutral, and rather than understeer being a problem out of slow corners on the power it was the inside wheels spinning up as I was WOT where normally I'd have had to moderate throttle...
Lovin' it and can't wait to get it aligned, and can recommend great positive results without squeaks and vibration from Quattro Corners bushes
)So - I heard Quattro Corner supply a set of high-density rubber bushes as a comprimise and decided to take a punt on them.I haven't had the car aligned yet but took it for a quick blast after picking it up last night for some first impressions.
