Are these right
  • s2driveruk
    • 12696
    Originally posted by Error404
    are you running fronts all round now David?
    Running avant fronts all round - had to as i broke a spring just before i went on the euro-trip in 2010 and thankfully Pete came to the rescue with a set of 4 - otherwise the bum end would have been sitting too low on the proper coupe ones.
    Still think the coupe sits nicer on the proper matched set but never found a set of fronts to use and to be honest have so little time to change them all over again
    1992 3b S2 Coupe
    • s2driveruk
      • 12696
      Originally posted by bilko0795
      What does HA/VAs stand for
      Hinten and Vorn (from memory) german for front and rear
      1992 3b S2 Coupe
      • Nuvo
        • Nov 2003
        • 3825
        Other way around, hinten = rear, vorne = front.
        • bilko0795
          • Feb 2011
          • 1883
          I also but like you it would be to costly to send them back to NikOlas so im stuck with them because i don,t know what car they are off. also £135 out of pocket:
          • bilko0795
            • Feb 2011
            • 1883
            Hi guys on closer inspection these are old springs or have been in storage a while and have been refurbed, on one spring there is evidence of rust that has not been cleaned properly and just repainted over not impressed and i would be careful of buying anything again from NikOlas. id be wary of anything he sells.
            • Nik0las
              • 1345
              • Country: Bulgaria
              #21
              all previous posts were deleted so I'm not going over this again.
              If you suggesting that this were old springs repainted they are not. Simple it will cost me 3 more to be striped, sand blasted, powder coated and repainted than the price I sold them to you. And I know what I sent you they were not repainted by hand this was factory paint. Aslo I told you that they were still in the box I never tested them! Also there is a chanse the kits came with wrong springs in first place - there was such cases with H&R back in time.
              sorry for the inconvenience.
              Test the springs and if you don't like them just rerurn them and I will refund you. Simple.
              • jbrentd
                • Dec 2009
                • 247
                Originally posted by twoqu
                Confirmation that the Koni springs were at least originally, green in colour with the part number 2220-1226. They were all apparently the same springs front and rear!
                http://www.s2forum.com/forum/showthread.php?t=9604
                I just started a thread on trying to identify a set of springs I have that fit your description. Any help would be appreciated.
                Thanks and sorry bilko for the threadjack.
                2001 A4 Avant QMS - FXK04'd
                1991 Audi CQ - Project
                1996 A4 12v Quattro Manual - SOLD
