Nylon is a very bad choice for bushes, it is hygroscopic, it will absorb water and expand when it gets wet and as it is pressed in to a metal surround that will not give it will thus indent the bush crushing it beyond it's elastic limit, then when it dries out in summer on a hot day it will shrink and end up loose and rattle about.
Solid subframe bush failure.
Carlos.
On the look out for less bits for my s2 saloon project. Now supporting myself by shooting for my food. www.airgunforum.co.ukComment
I was going to make a set, until I asked my old man.Current-2004 Impreza PPP wagon
Sold ABY-stockComment
Other thing I was wondering, the subframes are steel, could you fit steel ones, weld them in, then prime/paint etc?
Would allow the holes to be offset to get some castor.Current-2004 Impreza PPP wagon
Anyone have any drawings/is willing to share the dimensions of the bushings? I want to make some delrin bushings for me, I already made the inner control arm ones myself, but don't want to disassemble the subframe yet to take the dimensions.Comment
England must be a Country. :mischeif:Comment
Does this mean that Super Pro and Powerflex and the like are not made out of Nylon, but something else which is more suitable ?Nylon is a very bad choice for bushes, it is hygroscopic, it will absorb water and expand when it gets wet and as it is pressed in to a metal surround that will not give it will thus indent the bush crushing it beyond it's elastic limit, then when it dries out in summer on a hot day it will shrink and end up loose and rattle about.
Thanks.Comment
I think that AndyP has a set of bushes so I'll measure them up unless there is a drawing available?
Alternatively I could send the "scrap" to Bambridge if he wants to use some inserts machining titanium.Kingdoms are run by Kings, Dictatorships are run by Dictators.
It is light and strong.
