.Has anyone converted to electro hydraulic pump for steering
  • jade
    • Jan 2005
    • 1811
    Has anyone converted to electro hydraulic pump for steering, I am thinking of getting
    Rid of the tandem pump all together
    I was thinking of using a MR 2 one from a mk11 it could be fitted where the bomb was and still Retain the oil tank
    Anyone with thoughts on this
    Thanks
    RS 2 580HP
  • Kieron20V
    • Mar 2008
    • 1505
    I have, using mr2 pump as you say.
    But i don't have a 5 cylinder any more so can't say much about fitting place.
    I madr done brackets and its fitted to lh chassis rail so i can use original p line to steering rack.
    1994 URS4 Avant RS2+
    • martinws
      • Oct 2008
      • 917
      I have now bought a mk2 MR2 pump to fit to mine but u just have not got around to fitting yet. Its going on my typ85 90Q so fitting is different to an S2!
      • jade
        • Jan 2005
        • 1811
        Ok thanks for the feedback
        RS 2 580HP
        • Tonks4x4
          • Nov 2005
          • 3062
          What is the advantage of this?
          Audi Nut!!!
          • jade
            • Jan 2005
            • 1811
            Originally posted by martinws
            http://www.s2forum.com/forum/showthr...steering+power
            Looked at that have few questions
            So the pump runs all the time, how does it control flow it just run at full flow all the time
            RS 2 580HP
              AFAIK the MK2 pumps just run and run. The MK3 MR2 pumps have a speed controller built into the motor which takes a feed from the speed sensor so the motor winds down the faster you go, like servotronic but actually works.
              • martinws
                • Oct 2008
                • 917
                My plan was to have it on a disused dash switch to a relay so i could have it on or off. You could probably vary the voltage to it to change the assistance. I originally took the power steering off because i liked the feeling of the heavier steering and wanted to get as much weight off the front end as possible but iv now realised that the column is not built to have that much force put through it and flexes alot after a while. I bought the electric pump as something interesting to do really and mess about with variable assistance.
                  The flex you can feel is the torsion bar in the rack twisting. you need a manual rack to do it properly.
                  • jade
                    • Jan 2005
                    • 1811
                    I have vems so I could possably use that to control it
                    RS 2 580HP
                    • cooperquattro
                      • Jan 2011
                      • 815
                      i have a solution,use a bmw electro-hydraulic pas pump,couple with a potentiometer,and you have variable resistance,if you are clever enough,you can also incorporate a speed sensor into the circuit...so the faster you go the harder(or softer )the the steering is
                      • Tonks4x4
                        • Nov 2005
                        • 3062
                        I put a Vauxhall Corsa C electric steering column in my B2 80 and mated it to manual rack.
                        It has variable assistance via a potentiometer on the dash.
                        Audi Nut!!!
                        • cooperquattro
                          • Jan 2011
                          • 815
                          yes have seen that one brian in your project,an excellent idea,but requires more hands on approach that most wont be able to do(alloy welding and space behind the dash)
                          how does it feel???
                          the electo hydraulic ones use the existing pas rack and pipework with similar effects
                          • Tonks4x4
                            • Nov 2005
                            • 3062
                            how does it feel???
                            Ok I see, but I am still a little unsure of the benefit?
                            It can't be for weight saving? As one unit to replace the pump is marginal.
                            It can't be for converting to vacuum servo as you can just remove the front vein in the pump and cap the feed to the brake bomb.
                            So I don't see then need? That's what I was trying to ask.
                            Audi Nut!!!
                            • cooperquattro
                              • Jan 2011
                              • 815
                              i thought they were just trying to get rid of the bomb and make the steering variable reistance
